constant draw test?
Old Oct 17, 2009 | 12:53 PM
cjben's Avatar
cjben
constant draw test?
I need a refresher on how to do a constant draw test. The battery keeps dying in my 95 f150 after it sits for a couple days,and before I buy a new one,I want to make sure it is actually the battery and not something else causing the battery to die. I just unhook the negative battery cable and hook up a volt meter or test light,then see if the light comes on or see what the volt meter reads,correct? thanks for the help!!
Old Oct 17, 2009 | 01:19 PM
deeznuts822's Avatar
deeznuts822
U got it correct
Old Oct 18, 2009 | 01:02 AM
87 XLT's Avatar
87 XLT
You need to read miliamps or just use the 12 volt test lamp.
The radio & PCM memory will light the bulb slightly and thats not a problem.
If the bulb is brightly lit, thats a problem.
Old Oct 18, 2009 | 07:49 AM
TexasGuy001's Avatar
TexasGuy001
When you unhook the negative battery cable, where do you connect the multi-meter or test light?
Old Oct 18, 2009 | 08:02 AM
subford's Avatar
subford
The test light or meter goes between the negative post and the negative battery cable on the above test.
But you will have to disconnect the radio and the computer and make sure the hood light is not on for this test.
You may want to do a load test on the battery to find out if it is good or not.
With the battery fully charged put a about 500 amp (or what it is rated at) load on it for 15 seconds with a carbon pile and if does not drop below about 8.5 volts it is a good battery.
Old Oct 18, 2009 | 10:14 AM
cjben's Avatar
cjben
well, It passed the draw test, i guess my ten year old Optima finally bit the dust after 10 years and being put in several different vehicles,some of them not being started all winter. I would say i got my money's worth.
Old Oct 18, 2009 | 10:31 AM
Engine's Avatar
Engine
Subford - I've got a question for you. What is a "carbon pile"?
Sorry to sound stupid. I am no mechanic, but I can follow most conversations on this site without a problem. I have never heard of a carbon pile or this test.
Old Oct 18, 2009 | 10:39 AM
DBGrif91's Avatar
DBGrif91
You got 10 years out of a battery? Wow... yeah, I'd say you got your money's worth out of it alright.
Old Oct 18, 2009 | 10:46 AM
subford's Avatar
subford
The test with a carbon pile is the most common test there is for a battery. Ever place I ever worked at had one. I have of my own also. Mine is made by Sun (now Snap-On) and it has a volt meter, amp meter and a center **** for puting pressure on the carbon pile.
I think most places that sell batteries still have them around.
A carbon pile is a stack of carbon wafers and the more pressure you put on them the more they conduct.
It looks like this:
07EXPYEL
Jul 27, 2016 01:04 PM
MDSuperDuty
Dec 10, 2015 11:17 AM
dstark181
Nov 14, 2014 09:40 PM
areoseek
43
Nov 22, 2013 12:03 AM
kornfanjoe
Oct 21, 2013 07:26 AM
