Van instruments (1995)
Old Oct 18, 2009 | 07:53 PM
dwanderson's Avatar
dwanderson
Wow - great job. You've convinced me that what you did is the way to go. I'm off on a search for a suitable doner cluster. Thanks again!
Old Feb 13, 2010 | 11:51 AM
dwanderson's Avatar
dwanderson
Instrument cluster swap - 1995
Wow - I hope someone out there is still watching this thread. I finally obtained a 95 F series cluster for a transplant into my 95 van. The new cluster does have enough wire on the back so I can identify colors. I don't have the old cluster out yet (still winter here), but am I right in thinking I can wire this just by matching colors between the 2 clusters (except for having to run a tach signal)? I don't have a factory wiring diagram, but it sounds like if this is true that I can get by without one. Right? Wrong? Also I see an exposed resistor close to the rear of the oil pressure gauge. Is this the infamous resister that causes the gauge to act like an idiot light? I remember seeing a thread about cutting or jumping this resistor and replacing the sender to make the gauge actually move. Thanks in advance to anyone's help!!
Old Feb 13, 2010 | 12:51 PM
subford's Avatar
subford
Yes that is the infamous resister that causes the gauge to act like an idiot light.
If you need the 1995 E & F cluster diagrams just give me an email and I will try to help you out.
email address at bottom of post.
Old Mar 8, 2010 | 02:03 PM
Fox Fader's Avatar
Fox Fader
I just got my cluster in today.
I have a 93 E and read that the cluster's second character in the part number denotes the year of the cluster. True? Mine is a 3. I've done this type of swap fixing things on the cluster that didn't work right before, (98 Expl, 2000 cluster, 99 Miata, 2001 cluster), so I pretty good at it without using any schematics. Let's see how this goes.
FF
Old Mar 8, 2010 | 03:53 PM
subford's Avatar
subford
The first letter is the decade and the second character is the year of the drawing. The same drawing number may be used for a number of years. The Ford part number is not on the part however.
But most of the time it is the first year that part was used but a 93 number could be in a 1994 or even a 1999.
As far as the cluster goes only the 1992 and 1993 should have the same drawing number. The 1994 and 1995 are the same also but different from the 1993.
Old Mar 8, 2010 | 07:28 PM
Fox Fader's Avatar
Fox Fader
I'm gonna take care of the "idiot gauge" too.
Old Apr 14, 2010 | 02:32 PM
gravydude's Avatar
gravydude
The the connectors do not inter change, right? How do you get the milage to follow with the replacement? Or can you take the fixture apart and replace it? Is there an internal battery that will store the milage?
Sorry for the 100 questions, but this topic is interesting!
Thanks
Old Apr 14, 2010 | 03:00 PM
subford's Avatar
subford
What connections are you talking about? The plugs are the same but the pin out changes some from year to year.
Use your old PSOM in the new cluster.
What fixture? You can take the cluster apart and swap the PSOM or gauges.
No it is keep in flash memory inside the PSOM.
[/quote]
Old Apr 14, 2010 | 04:07 PM
Fox Fader's Avatar
Fox Fader
Thanks
Here's my write-up.
Old Apr 15, 2010 | 10:35 AM
gravydude's Avatar
gravydude
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o> </o>
<o> </o>
Awesome write up!!! Kudos’s to you!!<o></o>
<o></o>
I have a 95 150 with a 5 speed. It did not come with a factor tach, which amazed me.
Do you know if this will also fix my Speedo needle wiggle? Probably not because the Speedo is being changed over with the odometer.<o></o>
<o></o>
Now I have to do the junk yard search.
Thanks<o></o>
<o></o>
Old Apr 15, 2010 | 03:43 PM
Fox Fader's Avatar
Fox Fader
A jumpy speedo is usually the sensor.
The clusters are on ebay all the time.
Remember, my write-up is for a 93, hopefully your 95 will be typical.
Old Apr 15, 2010 | 03:54 PM
gearloose1's Avatar
gearloose1
Never hurts to clean all wires / connectors contacts while you area at it..
And blast out the conductive dust gathered in the dash innards.
big ole ford
Jul 19, 2016 07:01 PM
kountzecobra
Aug 9, 2015 02:14 PM
TrdLtly
1997 - 2003 F150
Jul 2, 2014 01:35 PM
stydel311
23
Nov 20, 2013 08:17 AM
cfvwd
15
Mar 31, 2012 06:39 AM
