carb problems? HELP!!!!
Old Oct 16, 2009 | 10:18 AM
84f250mudder's Avatar
84f250mudder
hey
i own a 1984 f-250 and the other day i was on my way to go pull my friend out of a hole when my truck just started bogging and wouldnt go past quater throttle without bogging out on me. i wasn't even inthe woods yet when it started so im thinking i might just have to spray some carb cleaner and that might do it. any suggestions would be greatly appreciated.
thanks...
Old Oct 16, 2009 | 11:24 AM
Chitownhillbilly's Avatar
Chitownhillbilly
Did you get some dark smoke from the tail pipe? First thing to check is how clean the Air Filter is, especially if you've been messin round in the mud.
Old Oct 16, 2009 | 11:58 AM
84f250mudder
no, no smoke at all and the air filter is still pretty clean....thats why im thinkin it might be a carb problem but im not sure what it exactly is
Old Oct 16, 2009 | 02:15 PM
bghnkinf250's Avatar
bghnkinf250
What type of engine and carb?
Old Oct 16, 2009 | 02:27 PM
84f250mudder
its a 351w with 58,xxx original miles and a stock 2 barrel carb
Old Oct 16, 2009 | 02:35 PM
bghnkinf250
Could it be a stuck float? Tap on the side of the carb with it running, see if it loosens up the float.
Old Oct 16, 2009 | 02:44 PM
84f250mudder
it might be...im workin on it first thing tomorow morning that will be the first thing ill try
Old Oct 16, 2009 | 11:04 PM
86bigred's Avatar
86bigred
with the air cleaner off ,below the choke plates you will see a large screw with 2 metering rods(high speed air bleeds).gently push down to make they are seated.if these are open it will idel and give a little bit of throttle but will bog if you give it more than 1/3 throttle.this happened to me and it took me the longest time to find.
this like might help.http://www.tekatlarge.com/Automobile...0%20Carb3.html
Old Oct 17, 2009 | 12:49 PM
84f250mudder
alright...i just tried that and it didnt do anything...my next thing will be to just spray some carb cleaner in there and see what that does
VicSevenSeven
May 5, 2013 09:46 PM
dohc_chump
Feb 20, 2010 03:37 PM
justin_jkj
Nov 9, 2007 10:09 AM
gingerbreadmaniac
Jun 14, 2005 01:12 AM
74F100Ranger
Aug 15, 2003 10:52 AM
