bog at wot
Old Aug 14, 2003 | 01:35 PM
74F100Ranger's Avatar
74F100Ranger
bog at wot
My truck has a bog problem,
When I floor it, it starts to bog out at 3850rpm to 4000rpm, and it won't climb any higher. Could this be valve float at such a low rpm. I acts like it wants to die but when I let off it goes back to normal. It is a 460 with edelbrock 750 carb. Any help would be appreciated.
Thanks,
Joel
Old Aug 14, 2003 | 05:09 PM
71cc's Avatar
71cc
bog at wot
I had a similar problem with weak spark, turned out to be a bad coil.. same symptoms
Old Aug 15, 2003 | 10:52 AM
Colossus's Avatar
Colossus
bog at wot
I have the same setup and noticed the same problem. I played around with the floats, the curb idle, and replaced the fuel pump, which has helped considerably.
bodabdan
Sep 29, 2016 09:51 PM
dougcepress
Modular V10 (6.8l)
May 10, 2016 04:12 PM
oldmerc
19
May 1, 2016 07:37 AM
Fordzilla80
1983 - 2012 Ranger & B-Series
38
Sep 26, 2011 10:25 AM
lacustoms
Nov 4, 2010 03:46 PM
