Engine bogging
Old May 3, 2013 | 09:46 PM
VicSevenSeven's Avatar
VicSevenSeven
Engine bogging
My 351m starts to bog out once I get to about half throttle or more. Anyone know what might be wrong? I was told it could be my carb needing adjustment.
Old May 4, 2013 | 09:02 AM
ctubutis's Avatar
ctubutis
I would check fuel pressure and flow rate, mine acted like it was running out of gas at anything more than 3,000 RPM and that was because of a restriction in fuel flow from the rear tank (had the wrong sending unit assembly back there, one that had a pump on it but the pump wasn't hooked up electrically).
Old May 5, 2013 | 09:46 PM
wyoming4x4's Avatar
wyoming4x4
check the carb.
the jets on the 2 barrel carb set on the btm and water and other bad things get in the jets sometimes. check and see if squirters are working properly also. good luck. sometimes the factory fuel filter just clog up and need a new one. many things possible with with trash in fuel.
taylorbickett5
Jun 2, 2019 10:45 PM
winginit
Sep 12, 2016 11:02 PM
martyanderson10
Mar 16, 2015 07:34 AM
Buyerz
Mar 22, 2014 07:27 AM
Kider
May 11, 2004 11:00 PM
