Sponsored by: Real Truck
Dual stabilizer's
Old Oct 15, 2009 | 08:48 PM
Headviking's Avatar
Headviking
Post Dual stabilizer's
Just received my order of Rough Country Dual stabilizers from Autotruck toys. I was wandering if anyone else has used there stabilizers? If so, did you get a boot for the stabilizer shocks. I thought that we needed them to keep the dirt off.
Old Oct 15, 2009 | 09:15 PM
06silvercrew's Avatar
06silvercrew
I have that kit, didnt come with boots. This is a common debate, alot will tell you no boots because they trap the crud, some will tell you boots to keep the crud out. I like the look of the boots and I dont go off road so I use them.
Old Oct 15, 2009 | 09:42 PM
Headviking's Avatar
Headviking
Post
Where did you get the boots from? It would be great if you could supply a link.
Old Oct 15, 2009 | 10:03 PM
dcf4x4's Avatar
dcf4x4
Had a dual stabilizer kit with boots last year. Now have the same exact kit without boots.
They've been on since April. No apparent leaks. The dirt and crud stuck on there isn't oily at all. They work great.
With that said, having boots makes it look nicer.
Interesting side note and rather important: The metal brackets that bolt to the axle have a tendency of breaking at the bends. I decided to weld flat stock to form a triangle support, joining the two bends and strengthening the bracket. Enameled it and no stress cracks yet.
Old Oct 16, 2009 | 04:50 AM
senix's Avatar
senix
try your local auto parts store or a 4x4 shop in your area.
Old Oct 16, 2009 | 10:03 AM
06silvercrew
Yeah, just about anywhere sells them, they are abut $3-$4 bucks each. I got them locally at the 4x4 shop.
Old Oct 16, 2009 | 07:01 PM
Headviking's Avatar
Headviking
Just finished installing the kit. Boy what a difference it makes. I do have another question. When I was installing the shock I had to extend the piston to reach the tie rod hookup. I found that it took a great deal of effort to extend. Does this put undue stress on the steering gear/pump?
Old Oct 16, 2009 | 08:04 PM
senix's Avatar
senix
don't think it does, you should be fine.
Old Oct 17, 2009 | 12:00 AM
dieselMD's Avatar
dieselMD
Is the dual stabilizer setup more for lifted trucks or would a silly fool like me with the stock setup benefit? Thanks
Old Oct 17, 2009 | 05:17 AM
senix's Avatar
senix
dual steering setup
I am using a dual setup. All I have is the off-road tires. For me I did it because I like my steering to be a little more firmer, more feedback. Plus it helps when running thru the fields.
Old Oct 17, 2009 | 07:16 PM
Headviking's Avatar
Headviking
I installed mine with a stock suspession. Just over sized tires.
Old Oct 18, 2009 | 10:27 AM
bldog's Avatar
bldog
wondering...can ya also leave the stock one inplace & end up running 3 stab. shocks?
Old Oct 18, 2009 | 11:19 AM
senix's Avatar
senix
My stock one is still in place. why remove it? no harm in it riding along.
Old Oct 18, 2009 | 09:56 PM
DAVE67FD's Avatar
DAVE67FD
headviking,
Curious on what you paid for them from Autotruck toys?
04F-250mark
Texas Chapter
Jan 21, 2011 06:30 PM
nghtrgr
Jun 2, 2010 12:34 AM
sweeted
Apr 27, 2010 08:03 PM
vento
Dec 4, 2009 01:00 PM
emmagator
Feb 25, 2008 08:16 PM
