I've searched on this topic and came up empty. I have a 2003 4x4 f150 Scab 5.4 with power locks. Is there a way to child proof the passenger door lock?
there are child safety locks that only allows the passenger doors to be open from the outside only if you are worried about them opening the door while you are driving. i've never heard of child safety door locks.
That would work just fine.
I would like to have a button that would deactivate the passenger side door lock so if the button is pushed on that side nothing happens unless I push a button on my side to reactiveate that side.
You do realize that you can still open the front passenger door (I assume this is the door we are talking about and not a back seat door) with the doors locked. All you have to do is pull the handle and it will push up the lock and open.
So - yes you could probably add a switch somewhere and wire it up or you could just unplug the power door lock switch on the passenger door.
However, if you pull the handle - the door will unlock and open anyway. Try it.
At least this is how it works on my 2002 Supercrew
