I have an 04 X and I have searched this forum withou luck
Is there a way to allow the truck to unlock all doors when the ignition is turned off?
I had an 4 door Colorado and I liked this function a lot since I child proofed the rear doors so they could not be opened from the inside.
I always find myself digging for my keys or opening up the driver door and hitting the unlock button.
If you have a key fob, you can hit unlock twice. if you use the keypad, press the number three 3 after you enter your pin. if you are inside the vehicle, get out and open the rear doors.
Yes it does, but all you have to do is get out, walk around to the passenger side and then realize you forgot to unlock the other doors a few times before you disable this feature.
I will have to try disabling the auto lock feature.
I just liked the way my chevy would auto unlock once I placed the truck in park
wish the X had this function also
