VIN needs decoding
Old Oct 5, 2009 | 10:39 PM
wyckedcombo17's Avatar
wyckedcombo17
VIN needs decoding
Hi all, I have a VIN that needs decoding for a 1970 F100 if you don't mind. I know it is a I6, don't know if thats a 240 or 300, and it is a 3-on-the-tree, but thats about it.
F10ACK23363
Thanks ahead of time, probably thanks NumberDummy
Old Oct 6, 2009 | 01:11 AM
jhooch's Avatar
jhooch
I believe A would be the 240.
Old Oct 6, 2009 | 03:49 PM
wyckedcombo17
if it is the 240 is that as reliable as the 300?
and these VIN decoders are impossible to find!
Old Oct 6, 2009 | 04:00 PM
wyckedcombo17
I found out it is the 240 / 1BBL made in October 1970 in Ontario.
Is the 240 as reliable as the 300? Cause I heard from a lot of people that the 300 was very reliable.
Old Oct 6, 2009 | 10:36 PM
Shoestring's Avatar
Shoestring
According to the fordification site the A is for the 240.
SS
Old Oct 6, 2009 | 10:53 PM
hogbus's Avatar
hogbus
you can try getting a MARTI report...lots of cool information on there..
Old Oct 7, 2009 | 10:12 PM
wyckedcombo17
yeah but the MARTI report costs more than the distrib. points im going to have to fix.
does the 240 have the same rap as reliable as the 300 though?
Old Oct 7, 2009 | 10:46 PM
Shoestring's Avatar
Shoestring
Have you seen wickedinhere's post on his truck? Check here. He has totally redone or at least slight rebuild of his 240 and it looks and according to him is very strong. Check it out.
SS
Old Oct 8, 2009 | 12:49 AM
jjdeal79's Avatar
jjdeal79
LMC Truck catalog has VIN # info: F10ACK23363 F10=F100 2WD A is the engine code which according to LMC yours is 6Cyl 240 1V carb C should be the assembly plant (Ontario) K23363 is the consecutive unit number. This is also in my original '68 shop manual. It should be in others. Hope this helps.
Old Oct 8, 2009 | 05:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Most VIN decoders found in aftermarket parts catalogs, and on the various websites are rife with errors and omissions.
The absolute worst VIN decoder is LMC's.
If you want factual info, the apropos parts catalog is the only reliable source.
I've decoded well over 700 VIN's here on FTE..using the parts catalogs only.
btw: 240 1V I-6 VIN engine code: J = 1965 only // A = 1966/74.
No 240 I-6's after 1974.
F10ACK23363
F10 = F100 2WD
A = 240 1V I-6
C = Oakville, Ontario Canada Assembly Plant. This does not mean the truck was only sold in Canada.
K = 1971 Numerical Sequence of Assembly (Serial Number).
I can also decode all the codes found on the Warranty Plate.
Old Oct 8, 2009 | 04:06 PM
wyckedcombo17
Alright thank you all for your help. I don't own the car yet so I cant give you the numbers off the warranty plate
