What needs greasing?
Old Oct 5, 2009 | 11:33 AM
6litrefan's Avatar
6litrefan
I have looked and looked and cannot find any grease zerks on my 07 F250...could someone please tell me what joints in my suspension need greasing?...Maybe even post pics of where these areas are located???....Thanks for the help guys!
Old Oct 5, 2009 | 11:57 AM
69cj's Avatar
69cj
On a 4 X 2 there are none.
Old Oct 5, 2009 | 12:53 PM
6litrefan's Avatar
6litrefan
Mine is a 4x4....
Old Oct 5, 2009 | 12:56 PM
npccpartsman's Avatar
npccpartsman
On my 04 there are a couple on the steering linkage but that's it. You might want to grease your rear driveshaft splines IF you have an extended or crewcab truck, but that requires a little disassembly and only if you get that annoying clunk. Later models may not have any zerks at all.
Old Oct 5, 2009 | 05:13 PM
69cj's Avatar
69cj
Havn't found any on mine Tim and as of yet no clunk in the driveline. Overall this has been a very good truck. May be looking at changing the upper CAC hose. It seems to be weeping a little.
Old Oct 5, 2009 | 05:56 PM
heavyiron's Avatar
heavyiron
My 07 has zerks on the uni's on the front axle. I'm sure your's will too.
Old Oct 5, 2009 | 06:21 PM
69cj's Avatar
69cj
That would be on a 4 X 4 not a 4 X 2.
Old Oct 5, 2009 | 07:19 PM
heavyiron's Avatar
heavyiron
Did I miss the info that this was a 2WD?
Old Oct 6, 2009 | 12:06 PM
6litrefan's Avatar
6litrefan
The truck i am refering to is 4 wheel drive....any more input on this i have looked up and down and can't find any grease points...but maybe i am not looking right???
Old Oct 6, 2009 | 12:57 PM
UGA33's Avatar
UGA33
These are the only two that are on the 05+ 4x4 trucks. That is it!
Old Oct 6, 2009 | 03:29 PM
Cowboy65's Avatar
Cowboy65
Follows is text from my 2006 Scheduled Maintenance guide:
* Lubricate ball joints and steering linkage if equipped with zerk fittings.
* Inspect and lubricate 4X4 front axle shaft U-joints (F250/350/450/550).
This is to be done every 15K miles.
On my truck the only zerk fittings that I have found are on the front axle shaft U-joints.
Greywolf
All Things Towing
26
May 14, 2018 09:35 PM
lakewood
May 3, 2012 10:22 PM
downeast nc
Dec 29, 2009 11:55 AM
87carbed
Garage & Workshop
24
Jun 22, 2005 03:42 AM
kameronth
1978 - 1996 Big Bronco
May 5, 2004 05:39 PM
