Changing both batteries...advice???
Old Oct 6, 2009 | 02:55 PM
Timon5435's Avatar
Timon5435
Time to change both batteries...purchased Interstate mtp-65. Anything special about changing both batteries. I read the tech folder info and it seems straight forward. I read somewhere about having to relearn the transmission??? Any advice is appreciated.
Old Oct 6, 2009 | 03:41 PM
Cowboy65's Avatar
Cowboy65
I've read that it is possible for the Transmission Adaptive Strategy to be cleared when batteries are changed. If you experience hard or slipping engagements then you can perform the relearn strategy to quickly return to normal shifting. Otherwise the transmission will relearn on it's own only it will take a longer time.
Old Oct 6, 2009 | 04:30 PM
69cj's Avatar
69cj
If you change 1 at a time leaving the other 1 connected you should have no problems. Just make sure you don't short or gnd. the positive while doing it.
