Sponsored by: Real Truck
How do you grease windows?
Old May 1, 2012 | 01:36 PM
lakewood's Avatar
lakewood
My front power windows are creaking pretty bad and sound like they need grease. Anyone who has done it, how do i do it? and what grease is best?
Its the 05 in my sig. Thanks
Old May 1, 2012 | 01:49 PM
cbzdel's Avatar
cbzdel
I have the same problem in my 2005 with manual windows
Old May 1, 2012 | 08:29 PM
lakewood's Avatar
lakewood
bump bump bump
Old May 1, 2012 | 08:44 PM
1973Ford2004's Avatar
1973Ford2004
Is it the rubber squeaking or the motor in the door?
Old May 1, 2012 | 09:34 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Check this out:
https://www.ford-trucks.com/forums/5...ndow-lube.html
Old May 1, 2012 | 10:51 PM
jh818's Avatar
jh818
Originally Posted by RedBoat
I stared at your avatar for a couple of minutes before I realized that there was a link to check out.
Old May 1, 2012 | 11:05 PM
Quad Racer's Avatar
Quad Racer
Link? what link?
Old May 2, 2012 | 12:20 AM
lakewood's Avatar
lakewood
Thanks for the link, ill probably get it done this weekend
Old May 2, 2012 | 10:12 AM
SuperDutyScaler's Avatar
SuperDutyScaler
i spray silicon spray inside the rubber seal around the door where the glass slides into. let it dry and windex the window clean. remove the door panel and use a waterproff grease on the little white rollers for the window arms, thjey are always 100% dry and need grease/lube bad! I use waterproof grease and i still regrease once a year to keep the window flying up and down the track. My truck wont win many 1/4 mile races but my windows sure would
Old May 2, 2012 | 10:15 AM
SuperDutyScaler
just thought of something, doesnt the 05 and newer Fords use them JUNK cable and pulley system now? My brother 2006 F150 does and both of his snapped? The only thing you could do to them is lube the cable with some cable lube
Old May 3, 2012 | 09:30 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
No they still use the metal rods no cable/pulley system on the F-250's.
Old May 3, 2012 | 10:22 PM
btred1466's Avatar
btred1466
distracted what are they talking about where is the link
02superstroker
Jul 15, 2015 12:59 PM
jnoble87
Jan 23, 2015 07:37 PM
BeerCan500
31
Sep 15, 2012 09:16 AM
Jbrown8988
Mar 2, 2009 08:06 PM
montanafordman
1997 - 2003 F150
Dec 1, 2007 07:47 PM
