Question for NumberDummy
First Digit: Decade
A = 1940's (often omitted)
B = 1950's
C = 1960's
D = 1970's
E = 1980's
F = 1990's
Second Digit: Year Number
Last digit of year of introduction or revision. This number corresponds to the decade shown in the first digit.
Thus C5 = 1965.
It is not a P/S ID tag, that was originally on a metal tag bolted to the housing.
This is a Ford P/S gearbox, prolly from a 1965/72 Galaxie/LTD, 1966/72 Fairlane/Torino (and etc), or 1969/72 F100/350, because in 1973, the ID number for that cover was D3AB.
However...
This P/S Gearbox uses two seal kits. These are the SAME kits from 1965 thru the 1990's for LTD's, Crown Vic's. Merc Grand Marquis, and etc.
These two kits also fit late 1969 thru 1996 F100/350's, 1978/96 Bronco's.
You CANNOT go by Ford ID, casting or part number prefixes to ID what years parts fit or what their application is!
Because....Ford is in-famous for updating 10's of 1000's of part numbers EVERY
year.In fact...
D7AZ3E501B .. Ford P/S Gearbox Sector Shaft Seal Kit / Available from Ford.
D7AZ3E501B replaced:: D7AZ3E501A, D3AZ3E501A, C5AZ3C538A.
F3AZ3E502A .. Ford P/S Gearbox Input Shaft Seal Kit / Available from Ford.
F3AZ3E502A replaced: D7AZ3E502A, D3AZ3E502A, C5AZ3C538A.
See what I mean?
Hobbyists who have zero Ford parts experience, zero knowledge on how Ford operates...should not be relied upon to post factual info.
C5TA-2795-1 (not a 1, prolly an A) is related to brake parts (2795: parking brake cable bracket).
Brake parts are in the 2000 group, rear axle parts are in the 4000 group.
4.10-1: This rear axle could be a Dana 60, Dana 60.2, Dana 60.3, Dana 61-1, or a Dana 70.
Look on the axle housing adjacent to the inspection cover for the bolted on Dana ID tag.
This tag is 2" x 1/2" and has seven or eight numbers on it. Like this: 603010-1 or 603010-11.
351C = 1970/74 Passenger Cars/Ranchero's only.
FMX: 1969/80 Passenger Cars/Ranchero's only, with one exception: 1973/77 F350's with the 300 I-6 used FMX's.
What it was originally installed in: 1965/66 F250's except 4WD, except Camper Specials.
The bolted on Dana ID tag was not used prior to 1973.
