C6 transmission
Old Oct 27, 2016 | 08:26 PM
7379ford's Avatar
7379ford
C6 transmission
I got a question about the c6, did they make a small block version 4x4 in 77-79. Also will an 80s c6 fit a 203/205 in a 78 f150 thanks in advance
Old Oct 28, 2016 | 05:33 AM
gatorfor88's Avatar
gatorfor88
no "small block" 4x4 in 77-79. An 80's c6 4x4 should be direct bolt in. 2wd will need some 4x4 parts installed.
Old Oct 28, 2016 | 07:34 AM
Filthy Beast's Avatar
Filthy Beast
Welcome to FTE. Lot's of good people here willing to help.
First, Ford never referred to their engines as "small block" or "big block." Hard asses on here will tell you that....and it's strictly GM nomenclature.
They're called the FE series or family, FT series, 335 series, 385 series. If your engine is a 351M/400 then you're in the 335 family. When you post up a question, it helps us to know with what engine, trans, etc we're discussing.
Not to smack you with a terminology hammer, just sayin.'
Old Oct 28, 2016 | 08:09 AM
Rollingscrapmetal's Avatar
Rollingscrapmetal
The 300 came in 4wds that year didn't it
Old Oct 28, 2016 | 08:39 AM
good to doo's Avatar
good to doo
Yes they did, manual only I believe.
Old Oct 28, 2016 | 09:00 AM
gittinwidit's Avatar
gittinwidit
The C6 never changed much internally throughout it's life. And was the Go-To tranny for Ford when they needed a strong transmission. The only thing that changed was the bell housings for they were integrated with the body of the transmission. The 4x4's had a different tail housing and tail shaft. There were 2 versions for the 2wd's as well being a shorter fixed yoke and a longer slip yoke. The F250 highboys used the short fixed yoke but also integrated a boss on the side to attach the t-case linkage. And lastly, the 4x4's had a deeper pan.
I have a c6 from a 94 International diesel that was the exact same internally as one from a '67 FE. Only difference I saw was the clutches were different. And I have bolted in a few 80's small block ford C6's into 78/79 bronco's. Also I will contest that besides the local hard heads on here, anytime you call a parts supplier even such as Jegs or Summit for parts for your C6, you will be referring to it as the "small block ford pattern" C6.
Old Oct 29, 2016 | 05:42 PM
winginit's Avatar
winginit
I guess that makes you are hard ***
Old Oct 29, 2016 | 06:49 PM
Filthy Beast
Reckt'um is does at that!
Old Oct 29, 2016 | 09:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978 was the first year that Ford offered the 300 & 302 w/a C6. Excepting 1969/77 Bronco's, there were no 302's available with 4WD until 1980.
Jeremys1088
Mar 21, 2013 03:36 PM
'73-'79CRAZED1!!
Ford Truck Parts for Sale
Nov 6, 2012 04:46 PM
atomicjoe23
Jan 5, 2012 03:39 PM
JoseCuervo
Feb 13, 2005 07:54 PM
The Tree
1978 - 1996 Big Bronco
Mar 22, 2003 12:33 AM
