A/C question
Old Jul 26, 2015 | 06:42 AM
hanklin's Avatar
hanklin
A/C question
A/C works fine coming out of vents but I get nothing towards my feet when I switch to dual (vent/floor) mode or floor only. Is there a door somewhere that is stuck?
Thanks
on my Exc btw
Old Jul 26, 2015 | 07:12 AM
Gene Horr's Avatar
Gene Horr
IIRC the diverter door works by vacuum. If so a vacuum leak or inop vacuum pump will cause this problem.
Old Jul 26, 2015 | 07:20 AM
hanklin's Avatar
hanklin
how do I diagnose and fix?
Old Jul 26, 2015 | 11:26 AM
projectSHO89's Avatar
projectSHO89
An inoperative vacuum pump or a vacuum leak in the primary vacuum supply will cause all airflow to go to the defroster, it will not affect only the panel/floor door.
The panel/floor door is not moving due to a faulty vacuum motor, linkage issue, door issue, or a control issue (vacuum leak or failed control unit).
Manual or electronic automatic climate control? The electronic control head uses solenoids to switch vacuum, the o-rings in the little solenoids tend to fail causing leaks and a loss of vacuum control.
pounder90
1997 - 2003 F150
Nov 5, 2018 06:51 PM
Suicidal
1997 - 2003 F150
Jan 14, 2015 10:05 AM
BigJake86
Jul 22, 2008 08:12 PM
jmasie
General Automotive Discussion
Jul 14, 2005 09:33 AM
JBronco
1978 - 1996 Big Bronco
Nov 16, 2001 08:50 AM
