Sponsored by: Auxito
trailer brake controller
Old Oct 1, 2009 | 07:27 PM
fordmerc's Avatar
fordmerc
I need to install a brake controller in my 97 and have heard about a harness that you can buy that you plug in under the dash somewhere and wire your controller to that. Just wondering if anyone has used this and might have a part # as well as a quick "how to" Thanks for any help!!
Old Oct 1, 2009 | 09:50 PM
steve(ill)'s Avatar
steve(ill)
plug is under the dash. you adapt the new harness to the new controller. sometimes you can buy the new controller already setup with the FORD plug- check that. You might need a relay to get the trailer brakes, etc to work. Some trucks did not have that. How many wires at the bumper plug, 4 or 7?
NEW OE FORD F150 EXPEDITION TRAILER BRAKE WIRE HARNESS:eBay Motors (item 250493168637 end time Oct-04-09 03:31:36 PDT)
Old Oct 1, 2009 | 10:30 PM
fordmerc's Avatar
fordmerc
I do have the factory tow package and have the round 7 pin plug at the hitch. I already have the controller. I got it from a friend that had it on a much older f-150 for a while and pulled it out before he sold the truck. The controller is a tekonsha voyager and has 4 wires coming out of it. It was manufactured may of 97 so the instructions do not include the new to 97 body style. I looked at that same harness on ebay right before I started this thread but the ebay add gives two part #s so I wasn't sure if it is the right one. Can anyone tell me what and where to look under the dash for the correct wiring harness? Thanks again!!
Old Oct 3, 2009 | 12:30 AM
rocks'r'friends's Avatar
rocks'r'friends
The wire harness you are looking for is located on the right side of the drivers footwell, a few inches right of the hood release. It is a 6(3x2) wire plug, though it only has 4 wires running to it blue, black, red and white (if I recall correctly). You can pick up the wire harness adapter at pretty much any parts store (I got one at princess auto). I cannot help you out with a part number, the packaging should tell you what it fits.
Old Oct 3, 2009 | 07:15 PM
fordmerc's Avatar
fordmerc
I found a harness at napa yesterday for $10 and hooked everything up last night. My controller plug was right on top of my obd 2 plug. Thanks for the help guys!!
Brute440
May 5, 2015 07:39 PM
my996duc1
6.7L Power Stroke Diesel
Jul 28, 2012 12:10 PM
ItsABeautClark
Aug 19, 2010 05:09 PM
smsperformance
Jun 19, 2010 08:52 PM
horsepuller
All Things Towing
Jan 12, 2002 04:51 PM
