swapping heads
Old Sep 22, 2009 | 03:44 PM
kadrocker's Avatar
kadrocker
swapping heads
I have a spare running 390 in my dads barn. If I was to take the heads off and clean them and fix them up to put on my current engine would that be ok?
An old timer at work said fresh heads might be too much for an older engine like mine. That I really ought to rebuild my whole engine before throwing on fresh heads. Think there's any truth to that? I don't wanna hotrod my truck any, just stock specs.
Old Sep 22, 2009 | 06:20 PM
mark a.'s Avatar
mark a.
Depende on your engine. Does it have a lot of miles ?
Old Sep 22, 2009 | 06:42 PM
kadrocker's Avatar
kadrocker
90k miles. Previous owner said it was rebuilt 2 uears ago but I don't believe it.
Old Sep 22, 2009 | 11:30 PM
mark a.'s Avatar
mark a.
Whats wrong with your heads ?
Old Sep 23, 2009 | 12:28 AM
kadrocker's Avatar
kadrocker
My engine smokes some when running. When I take off the oil cap from the valve cover smoke comes out.
A guy at work said I should clean my heads up. I figured I'd just use the heads from my spare engine and put them on.
However he said I almost shouldn't bother because if I put nice clean heads on that my engine might not be able to take it.
He's got me confused...
Old Sep 23, 2009 | 01:25 AM
jhooch's Avatar
jhooch
If it's just the valve guides in your heads causing the problem and your bottom end is o.k., the head swap would be fine. Are you sure of the condition of the heads in the barn? You do have a lot of unanswered questions as to the condition of your bottom end also...
boxer.fan
Jul 14, 2009 10:44 PM
cts1954
17
Jun 27, 2009 01:32 PM
bigtorque
Jan 18, 2007 07:55 PM
F-ONE
Dec 8, 2003 04:32 PM
dogdays
18
Oct 15, 2003 05:17 PM
