diff fluid
Old Sep 20, 2009 | 08:52 PM
petroskie's Avatar
petroskie
diff fluid
so i changed my front, t-case, and rear diff fluids and the front was dark, looked like normal wear to me, same as the t-case, but the rear diff was a thick carmel color that i had never seen before, my thought was water in the diff, but from were i wondered, anybody have any ideas?
Old Sep 20, 2009 | 09:42 PM
Brooksd1991's Avatar
Brooksd1991
plug may have been loose was it tight coming off
Old Sep 20, 2009 | 09:46 PM
petroskie's Avatar
petroskie
rear diff
no plug was really tight, and theres no leaks anywere on the axle
Old Sep 21, 2009 | 08:00 AM
Diesel_Brad's Avatar
Diesel_Brad
Well your front and rear diff take gear oil and your t-case takes ATF . So the fluids should look differnt.
Now. Some rear diffs used synthetic gear oil while "all" front diffs use standard gear oil. And if you had water in your gear oil it would be a lighter color and milky
Old Sep 21, 2009 | 08:41 AM
ctubutis's Avatar
ctubutis
Originally Posted by Diesel_Brad
..."all" front diffs use standard gear oil.
The specs for mine call for using a variant for Hypoid gears.
Old Sep 21, 2009 | 09:42 AM
petroskie's Avatar
petroskie
according to the haynes manual it takes 90w in the front and rear and atf dextron/mercron in the t-cse
Jim-bo77
Feb 5, 2014 05:33 AM
bronco2454
May 19, 2008 05:14 PM
BillyBob69
1997 - 2003 F150
Jan 5, 2007 01:05 PM
monmar
Feb 20, 2006 09:21 PM
peppy
Feb 19, 2004 09:57 PM
