1976 Highboy tcase & rear end
Old Feb 19, 2006 | 07:35 PM
monmar's Avatar
monmar
The numbers on my divorced T case are C11313, I am looking for feed back on this Tcase good bad etc. Is it geared or chain. Just some info please. Also I don't have a tag on the rear end, what was the stock gearing for the rear and front diffs.
Thanks
Monmar
Old Feb 19, 2006 | 08:27 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
most likely 4.10 gears
most likely an np205, which is gear driven, very reliable and bulletproof
Old Feb 19, 2006 | 10:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Feb 19, 2006 | 11:21 PM
Thomasm67's Avatar
Thomasm67
You have a Hiboy i have one your's should be equiped with D60 rear and D44HD front with 4.10.s T-case should be a NP205 is the tranny a 4spd NP 435 or an auto C6?
Old Feb 20, 2006 | 08:18 AM
monmar's Avatar
monmar
It was a 4 speed and now an auto, not sure which one but probably C6.If the numbers C11313 don't indicate, what other ID marks will indicate.
Tks
Old Feb 20, 2006 | 02:49 PM
Thomasm67's Avatar
Thomasm67
It's a 205 it is divorced from the C6 right?
Old Feb 20, 2006 | 03:28 PM
64F260's Avatar
64F260
As they stated it is probably an NP205. It has a good reputation as being tough and reliable. Cast iron case. It is all gears, no chain. It was also used in other vehicles, and some were mated directly to transmissions, not divorced. I've heard that it can be converted to "twin-stick," the 4-wheel guys like to do that, it gives you the option of engaging either front or rear axle independently or together. You might want to double-check though , it may be a Spicer 24. (I have been looking for a Spicer 24 for my 1964, and a couple of sources show it was used into the 1970's on Ford trucks...) Correct me if I'm wrong here guys..
(I have pics of a Spicer 24 on my Gallery..)
Old Feb 20, 2006 | 04:31 PM
monmar's Avatar
monmar
Yes Thomas67 it is divorced from the C6. Its tough to do by your self, but my shifter feels very spongy. When I go to engage the Tcase, I can literally move the floor shifter forward and back, I need to roll the truck forward or back to engage the Tcase. My problem is I can't see if what is happening at the Tcase when I am in the cab...hahaha.. It used to be a solid engage but recently, very spongy...any thoughts?? When I do get it locken in, it is solid and works great.
Thanks guys
Old Feb 20, 2006 | 08:48 PM
Thomasm67's Avatar
Thomasm67
I've hadn't felt mine like that but here is a link you can contact them they will probly be able to answer your question better than me. Maybe some came before 73 but everyone i have seen were 205's.
http://www.high-impact.net/transmission_and_gear/Tcase_NP205.htm
Old Feb 20, 2006 | 09:01 PM
monmar's Avatar
monmar
Great site Thomasm67, thanks
Mark
Old Feb 20, 2006 | 09:21 PM
Thomasm67's Avatar
Thomasm67
Your welcome Mark
ManfredVonRichtofen
Mar 21, 2017 01:06 PM
Amphihauler
Oct 15, 2016 05:10 PM
No704
Jun 3, 2016 02:33 PM
Tomahawk
Jul 10, 2014 01:03 AM
flat4vw
Jun 22, 2011 09:04 PM
