HPOP Cyringe
Sep 24, 2009 | 01:54 PM
bored!!!!!!!!!-i just thought id use Tayln tool to take out the top end oil!
Sep 24, 2009 | 02:04 PM
You dont have to change it, but its a good way to get things clean.
Sep 24, 2009 | 02:29 PM
so is the cyringe for removing the top end oil Taylyn and if so which plug would i drain it from?
Sep 24, 2009 | 03:36 PM
That's how you get the oil out of the HPOP, you pull the fill plug on the top and suck it out.
Then you fill it back up.
Mine takes almost a qt.
Like I said, you don't have too, but its something to do to get more old oil out.
Sep 24, 2009 | 03:37 PM
Sep 24, 2009 | 04:39 PM
in my pic is it the plug on the left or right?
Sep 24, 2009 | 06:10 PM
Sep 24, 2009 | 10:00 PM
kupiec, like william said, the plug is on the right. there are only 2 ports (locations) that will get you inside the hpop to drain.... the allen and the oil pressure sender. the stud and nut you have an arrow pointing to (along with the 4others just like it) will remove the entire resevoir. you dont want to do that just to change the oil
Sep 25, 2009 | 08:51 AM
cuttn4fun
15
Feb 9, 2016 12:07 PM
Fat_Batster
54
Jan 5, 2016 05:43 PM
schlepprock250
Dec 21, 2014 01:56 PM
r-kid
18
Jan 19, 2014 03:11 PM
Tenn01PSD350
71
May 14, 2008 10:58 PM
