need help picking out an ATF for my truck.
Old 09-18-2009, 07:34 AM
afonda's Avatar
afonda
afonda is offline
I was at walmart checking out what they had in stock.
they have the
--walmart brand ATF for $2.70 per qt.
--Valvoline High Mileage ATF for $3.30 qt
--Penzoil AFT for about $13.00 a gallon
Is there anything wrong with the WalMart brand ATF?
Is It bad to use the High Mileage ATF?
Old 09-18-2009, 07:38 AM
just another truck's Avatar
just another truck
just another truck is offline
I will give you a quote from my old auto shop teacher " If you keep up on your Maintenance, and do your oil changes when you are supposed to, then any oil will work"
That being said, I always go with a higher end oil, and it is always a synthetic that I use..And yes, I am including trans fluid as a oil..
Old 09-18-2009, 07:41 AM
12ozd's Avatar
12ozd
12ozd is offline
Mine said the same thing!
Good advice that I still follow.
Old 09-18-2009, 08:02 AM
big poppa's Avatar
big poppa
big poppa is offline
Well guys, I understand where your coming from, scheduled fluid changes are key but ANY fluids I would have to disagree. Especially with tranny fluid, you want to make sure it compatable with your trans, Mark our tranny expert would tell us so. If it says Mercon or Mercon V you can use it, not sure about just ATF, might want to wait for more chime ins. With all these changes with you can use this now, you can't use this, very confusing.
Old 09-18-2009, 08:06 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
As long as it is Mercon or Mercon V, then it is fine. Not ANY ATF...
I personally use Mobil1 Syn ATF (Mercon V) in mine. Not cheap... LOL
Old 09-18-2009, 09:20 AM
just another truck
I should have been more clear.. but yes, if it says Mercon, it is Mercon, Sorry about that, I did not mean to mislead.. Thanks guys for covering my vagueness!!
Old 09-18-2009, 09:25 AM
12ozd's Avatar
12ozd
12ozd is offline
Agreed,I took the question as brand specific.
(i.e. pennzoil vs. wal-mart vs.valvoline vs. ........)
Wrathfulram
1983 - 2012 Ranger & B-Series
03-30-2015 08:53 PM
02sd
01-02-2015 06:23 PM
sledhead999
05-31-2014 06:42 PM
BeerCan500
Oil & Lubrication
09-13-2012 09:24 AM
grbr95
Oil & Lubrication
10-10-2005 11:10 AM
Quick Reply: need help picking out an ATF for my truck.
