4R100 Fluid, Opinions?
What is everyone running in their transmission?
I seen in another thread, Mark K. said everyone can benefit from running Mercon V...
Options:
Valvoline Max Life Dex/Merc $4.25/qt
Valvoline Dex/Merc $4.25/qt
Valvoline Mercon V $6/qt
Mobil 1 Synthetic ATF $10/qt
Royal Purple Max ATF $15/qt
Options:
No Dex/Merc! That is not licensed by Ford so it is not tested and proven to have the correct attributes.
Mercon V is licensed by Ford so it is tested and proven to have the correct attributes. Can't go wrong with that.
Or any fancy synthetic that floats your boat. I don't think they provide any significant additional benefit, but to each his own. Mobil 1 and Schaeffers seem to be common choices.
The Dex/Merc says it meet BOTH specs...
"Helps provide smooth shift performance where Dexron-III or a Mercon fluid is specified"
"Recommended for use in GM, Ford, Mazda, Toyota, and other import vehicles"
I'm leaning toward the Valvoline Mercon V, but was somewhat interested in the Max Life since its recommended over 75K miles.
The Mobil 1, Royal Purple, Shaffers is a bit pricey...
Before Ford discontinued MERCON in order for a manufacturer to state that it was a MERCON fluid they had to submit samples for testing to Ford. We ran that fluid through a battery of tests to prove that it met the specs. Ford no longer licenses MERCON fluid, so they are not testing it. Maybe it does meet the specs. Only the fluid manufacturer knows for certain. Before I knew that Ford was checking. They still are for MERCON V.
Super Tech Mercon V $4.27/qt
Normally I wouldn't consider running it, but with Ford's stamp of approval, makes ya think twice. $1.72/qt cheaper than Valvoline, not a ton but worth noting.
