Correct power steering fluid?
Old Mar 26, 2015 | 08:32 PM
Wrathfulram's Avatar
Wrathfulram
Valvoline MaxLife Dexron / Mercon Automatic Transmission Fluid, 1 qt. - Walmart.com
My 99 Ford Ranger XLT calls for MERCON ATF
The store employee told me to get this instead
Super Tech Automatic Transmission Fluid - Walmart.com
Thank you for your time!
Old Mar 26, 2015 | 10:57 PM
pawpaw's Avatar
pawpaw
Ford no longer licenses Mercon & has back specified Mercon V to be used in place of the old Mercon fluid on this TSB 07-1-7***MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS.
Mercon V is a semi-synthetic fluid that's a higher quality than the old Mercon recipe.
All that said, you could use either of the above fluids, or a Mercon V fluid in your power steering system. If your drive cycle is severe, with lots of slow city driving in hot weather, I'd consider using the full synthetic Maxlife, or a Mercon V fluid, or the less expensive WalMart fluid in that order. Some thoughts for consideration.
EDIT: BTW Welcome to FTE.
Old Mar 29, 2015 | 01:13 AM
drb1956's Avatar
drb1956
Super Tech
I use Super Tech in my Ranger. As long as it has Mercon application, its good.
Old Mar 29, 2015 | 01:54 PM
reddog99's Avatar
reddog99
Unfortunately, that oil doesn't look like it meets the Mercon V spec. (but the Valvoline does).
Old Mar 29, 2015 | 09:41 PM
drb1956's Avatar
drb1956
Its a '99, FCOL, its got MERCON and NOT MERCON V in the system already. He can USE any brand that meets MERCON requirements. WTH!!!Splitting hairs here!!! No wonder the world is in chaos, nobody just wants to get along...
Old Mar 30, 2015 | 08:53 PM
wtroger's Avatar
wtroger
Agreed. just use dextron / mercon fluid.
Milwaukee1979F150
16
Sep 3, 2011 02:21 PM
Bigol350
Nov 25, 2009 02:26 PM
Redranger03
Oct 1, 2009 03:48 PM
DrFord
16
Dec 2, 2008 11:17 AM
Old Speed
Jun 13, 2005 06:45 AM
