It's rusting
Old Sep 17, 2009 | 07:05 PM
DieselCamper01's Avatar
DieselCamper01
I bet if we took a poll you would find out most of us have the rust start on the drivers side. That sees the most salt when driving and it gets forced in everywhere. While I agree there are some issues of cheapness Ford could address, all the manufacturers suffer from rust issues.
Old Sep 17, 2009 | 07:08 PM
Buzzard_Wing's Avatar
Buzzard_Wing
I just sold a 95 because of rust and I am seeing the same pattern in my 01.
But on the positive side, there is only one gas tank.... and it's plastic.
Why does Ford seem to be worse than the others when it comes to rust??
Old Sep 17, 2009 | 07:18 PM
mudman00x's Avatar
mudman00x
Unhappy
i also have a rust problem that i have been dealing with on my 2000 ex spent 3 days cleaning up the under side and priming and painting where you cant even see, now the left rear wheel well is bubbling and i cant get at the inner area thats rustng so gotta cut it out and weld in a new piece then im getting some type of low profile flares, what really sucks is my 97 gmc plow truck has really no rust on the body panels and i plow alot with it what gives
Old Sep 17, 2009 | 07:30 PM
rmilchman's Avatar
rmilchman
Originally Posted by blue1ton
My 2002 F350 also rusted along the driver side rear fender area, paint started to bubble first, then the rust came. Took it to the dealer after the warranty expired a few months earlier. Service Manager said it was not Ford's fault, even after admiting my truck was well taken care of. Service Manager said he would call a Ford Rep after I continued to complain and remind them I was a loyal customer. With that said Ford denied my claim, so I no longer take my truck to that dealer and do most routine maintance myself. I ended up getting my truck repaired at a local body shop. They had to replace the L/R fender and repaint. Truck looks great again, even that bodyshop owner said it was weird how the left rear driver side fender rusted. I personally think this is a Ford issue just like the oil pans that are rusting. I really enjoy my truck but disapointed Ford will not stand behind issues such as this. I am also noticing a rust problem lower driver side door.
Thanks for reminding me. I need to cleanup the pan also. I already use POR but it must not have been perfectly clean as it is pealing off.
Old Sep 17, 2009 | 07:42 PM
big poppa's Avatar
big poppa
I have spots starting too, above the rear wheelwells on the bed, under the drivers and passender side cab, and a few spots hear and there, trying to nip it as fast as I can. I had spots on my oil pan that I sanded and patched up but their coming back, in other spots too, stinks. I really need to take care of the oil pan, big problems right there if that gets out of hand..
Old Sep 17, 2009 | 07:53 PM
74baja's Avatar
74baja
When my rear wheel arches started to rust, I cut the rust out, the used gorilla hair and covered with flares. They are possibly the dumbest design I have ever seen. The two pieces have this foamy stuff sandwiched between them, and no weep holes. So, when water inevitably gets in there, it gets soaked up by the foamy stuff like a sponge, and is held right up against the inside of the sheet metal. . I might do the line-x rockers, I think it would look cool anyway.
Old Sep 17, 2009 | 08:15 PM
parkland's Avatar
parkland
how come nobody sells stainless steel replacement panels?
Sheets of stainless arent that expensive,
Old Sep 17, 2009 | 08:46 PM
dadsgreenpsd's Avatar
dadsgreenpsd
I have the same rust problem, with an added bonus. I was putting fuel in my truck the other day, and noticed fuel dripping. My filler pipe has rusted out....
Anybody replace theirs? Where can I get one?
Thanks, and sorry for the hijack.
2000b2500
Paint & Bodywork
Aug 19, 2009 08:32 AM
projectdagger
Paint & Bodywork
Jul 23, 2007 06:57 AM
ahall8
Paint & Bodywork
Apr 3, 2007 11:26 AM
swilk
1997 - 2003 F150
Feb 18, 2006 12:29 AM
blackcherrymusta
1997 - 2003 F150
Jul 2, 2005 05:23 PM
