Evans NPG+ Coolant
Old Sep 14, 2009 | 05:52 PM
DocB's Avatar
DocB
Evans NPG+ Coolant
Hello Fellas,
Would like to know what you guys think about this stuff, especially if you use it.
And if you don't, why not ? (other than price).
From my research, it seems to be able to do everything that OATs and HOATs and ELCs can do, but better.
Plus no electrolysis and no corrosion. And good to 500K+ miles.
I'm just wondering if it has all these good properties, why it is not used more?
I was thinking of flushing and switching over to this coolant, but wanted to hear what you had to say first. Don't want to do any damage.
Truck in Sig. Do it?
Sig:2002 F350 7.3L PSD HO SCLB HD 4X4 6-SPD LS 3.73
Bilsteins, Mag-Hytec Diff. Cover, FS-2500 Bypass Filter, Billet T-Stat Housing, 203* T-Stat, 4" MBRP SS TB.
Old Sep 14, 2009 | 07:41 PM
clux's Avatar
clux
The reason I'm not using it is the price, availability issues, and the fact that it gets thicker at lower temperatures, as well as the whole rigmarole you have to go through to switch from aqueous cooolant. We have a lot of problems getting all of the water out of these blocks.
Old Sep 17, 2009 | 10:36 PM
DocB's Avatar
DocB
Thanks for the info.
Old Sep 17, 2009 | 11:08 PM
mongo75's Avatar
mongo75
It wouldn't be hard to dry the block out, just disconnect the radiator hoses, and run it down the freeway for about 30 minutes, that should dry her up inside real good LOL!
Old Sep 17, 2009 | 11:11 PM
CampSpringsJohn's Avatar
CampSpringsJohn
I assume you have done this before! Experience is a wonderful teacher.
Old Sep 18, 2009 | 03:40 AM
bfife's Avatar
bfife
still plays with trucks
Doc, I've been using Evans since 2003. I like the facts you listed but also like the zero pressure system. no blown hoses etc. as far as cold weather operation I've seen 20 below several times and never had an issue. my hot weather temps stay down even when towing heavy over steep mtn grades. price and availability are issues but the pluses outway the minuses for me.
Barney
86-IDI
Mar 10, 2015 01:12 AM
Gage2502
Feb 24, 2011 08:21 PM
Gage2502
Apr 16, 2008 11:46 PM
ReAX
Jan 11, 2007 10:12 PM
BigDawg54
Nov 17, 2003 07:42 AM
