Engine compartment light?
Old Sep 14, 2009 | 05:43 PM
dvldog458's Avatar
dvldog458
Question Engine compartment light?
Do all Excursions have a light in the engine bay? I've seen them (OEM) wired to the underside of the hood. For some reason my Ex doesn't have one.
Is it a simple plugin wire I could purchase from Ford?
Old Sep 14, 2009 | 06:24 PM
william_04_x's Avatar
william_04_x
IIRC, you have to buy an expensive harness that has the plug for the underhood light and the underhood light assy..
Old Sep 14, 2009 | 08:21 PM
mgs's Avatar
mgs
My 03 Limited does, Mike.
Old Sep 15, 2009 | 02:47 AM
housedad's Avatar
housedad
You can start your search after reading the following thread:
https://www.ford-trucks.com/forums/7...ood-light.html
There are several things they lefto off the 04's and 05's.
Underhood blanket,
cubby mat
console mat
underhood light
door courtesy lights.
The blanket and light and the door lights can be retrofitted. Ask for info and we can direct you to previous threads.
be sure to check out Jekuo's gallery in the following thread:
https://www.ford-trucks.com/forums/4...y-05-f350.html
http://https://www.ford-trucks.com/f...d-blanket.html
https://www.ford-trucks.com/forums/4...sion-have.html
Old Sep 15, 2009 | 02:53 AM
housedad's Avatar
housedad
And, no, you do not have to buy a expensive harness. they are too easy to make. Wire, electrical tape, flexible cable sheeth, crimp ends, some cable ties, an you are in business.
Heck I did it! Run a harness to the battery
Check the link below:
http://http://rides.webshots.com/alb...ElbXoe?start=0
Old Sep 15, 2009 | 07:15 AM
katiesdad7's Avatar
katiesdad7
I can save you all a bunch of $. Just don't open the hood at night. That will be $29.00 please. :-)
Old Sep 15, 2009 | 07:27 AM
YellowSled's Avatar
YellowSled
my 02 has the light.. and it works too.
Old Sep 15, 2009 | 09:08 AM
VaSheriff's Avatar
VaSheriff
The little lights under the hood are next to useless. All you need to do is get a mini 12V fluorescent shop light. The kind that has the alligator climps you attach to the battery terminals. And you have 25 times more light.
Old Sep 17, 2009 | 08:27 AM
HD RULES's Avatar
HD RULES
Agreed. Better off carrying a flashlight. Got plenty of room for it.
stuckstudent
30
Jun 2, 2023 07:36 PM
jasindude1
Apr 13, 2016 05:06 PM
greenmachine55
Apr 18, 2015 12:59 PM
40 oz
Oct 28, 2012 07:48 PM
tomkat5
Jul 16, 2008 03:32 AM
