Under Hood Light
Old Feb 11, 2008 | 03:42 PM
sltrrco's Avatar
sltrrco
Under Hood Light
I have question for all of the X owners out there, I have a 2004 X Limited and it dose not have a light under the hood is there a way to add one?
Old Feb 11, 2008 | 03:50 PM
i eat hybrids's Avatar
i eat hybrids
Ya u can. But it depends on if u want a switch in ur cab to turn it on or if u want it to come on when u open the hood?
Old Feb 11, 2008 | 09:20 PM
njstevens's Avatar
njstevens
Go with the open hood. I am suprised to hear that not all Ex's came with a hood light.
Old Feb 11, 2008 | 09:37 PM
i eat hybrids
Thats what i would do to. It would be a PIA to flip that swtich everytime u opend the truck. Two step processes suck lol. Anyways, i didnt kno that either NJ, I thought it was only a certain model years didnt come with the heat shield installed under the hood.
Old Feb 11, 2008 | 09:39 PM
aortizexcursion's Avatar
aortizexcursion
Ford stopped putting them on in 2004, so 05's and 04's do not have a light under the hood. I guess they figured this would save them money by not putting those lights in just like they how they did away with the rear center armrest cupholders, rear center air vent the glove compartment light and the courtesy light in the front doors, am I missing anything else? They wanted to profit just a bit more on an already highly profitable vehicle.
Putting a light under the hood should be an easy mod right? I'm thinking one would just need everything from the older Excursions that came with a light.
Old Feb 11, 2008 | 10:04 PM
i eat hybrids
Ya to bad the vehicle didnt last much longer Anyways, the only thing that has got me thinking, is how do u get the light to turn on when u open the hood?
Old Feb 11, 2008 | 10:20 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I think its crap. My 01 has the hood blanket and light but my 04 doesn't its like what was ford thinking when they mad the 03 and up trucks
aortizexcursion
Probably some sensor or something. If I had a newer model Excursion I would just buy a kit from an older Excursion and hopefully it could just be slapped in there.
Old Feb 12, 2008 | 12:04 AM
i eat hybrids
Mayb the Op can go to a junk yard? Get one off of a ex/250/350/450/550. They all gotta have the same wirin for the hood light
Old Feb 12, 2008 | 12:34 AM
afreemanmd's Avatar
afreemanmd
Haha what you mean? Its a GOOD thing they didn't last much longer. At the FMCO was taking off parts to save $$, we'd be lucky if a 2008 X even had doors
Old Feb 12, 2008 | 06:53 AM
DSMMH's Avatar
DSMMH
Easy to add!
Go to a dealer and get the underhood lite kit for a pre 04 X or superduty. You will get a lite fixture with bulb, wire harness and connector for about $20. The harness snaps right in to the pre drilled hood under the balnket. Then cut off the connector and run it to the battery. I did this on mine and it works great.
OBTW - I went to Ford and wanted to get the lite kit for my X. They actually listed a kit. The dealer told me, are you ready for this, the lite kit with required engine harness to plug the lite connector in to was $750. Yup, thats right. Saw it with my own eyes.
DSMMH
Old Feb 12, 2008 | 07:25 AM
housedad's Avatar
housedad
I made my own harness for the underhood light and hooked it into my fog light harness that I had to install to get fogs.
You can see a pic of the wire installation CLICK HERE
Had to install a underhood blanket and rubber wind shields too. There were no lights in the doors, either. Had to add them.
Added a lock switch to the rear interior quarter panel so I could lock the doors from the rear hatch like on my wifes Mountaineer.
They left too many things off of the 05's.
Matt M, PA's Avatar
Matt M, PA
It annoyed me that my truck did not have the light and blanket under hood. I too bought the light unit and hooked it up. (I also added the hood blanket.) This switch has a mechanism that turns it on when the hood is tilted. It had a clip that attached it to the underside of the hood. Since I had installed fog lights too, I tied the underhood light to the fog light circuit...the parking lights need to be on for the underhood light to work.
EDIT...Housedad beat me to it...I did the same thing for wiring.
DSMMH... I assume that you are speaking about a $700 for light package? I got mine from the dealer in 2005 for around $300 if memory serves. Ebay was even cheaper.
Old Feb 12, 2008 | 07:28 AM
housedad's Avatar
housedad
Interesting.
I tied mine into the power feed from the battery that I installed for the fogs. It will stay on indefinately. It will not turn off when the lighting timer resets.
edit: It will turn off when the hood closes,though!!1
Old Feb 12, 2008 | 09:51 AM
Downriver Thunder's Avatar
Downriver Thunder
My 2000's hood light hasn't worked since 2002. Not the bulb either.
