light and wipper switch knobs??
Old Sep 12, 2009 | 11:36 AM
spinach's Avatar
spinach
light and wipper switch *****??
Do these ***** just pull off, or do they have some kind of release on the back side? The wipers are stuck, thought it might be the switch.
Old Sep 12, 2009 | 11:39 AM
Localsalt's Avatar
Localsalt
there is a release. and a special tool to remove them. search for the tool to get a good idea on how to remove them
Old Sep 12, 2009 | 12:17 PM
EPNCSU2006's Avatar
EPNCSU2006
A thin flathead screw driver works too.
Old Sep 12, 2009 | 01:09 PM
luv2huntnfish's Avatar
luv2huntnfish
The light switch has a release button on it that lets the whole **** and stem pull out. Its under the dash and kinda hard to reach.
Old Sep 13, 2009 | 12:27 PM
EPNCSU2006's Avatar
EPNCSU2006
it might help to know what we're working on here, but I have no problem getting the ***** off from the driver seat with the flathead screwdriver on my swiss army knife.
Old Sep 13, 2009 | 01:18 PM
spinach's Avatar
spinach
87 F250, they don't just pull off like the 1970's fords.
Old Sep 13, 2009 | 02:33 PM
Alvin in AZ's Avatar
Alvin in AZ
http://www.panix.com/~alvinj/file12/coverlights.jpg
That shows the button near the front of the switch
and the threaded nut that came off it.
Here's the tool I made for that nut and fits the one
on the wiper switch too...
http://www.panix.com/~alvinj/file12/switchtool.jpg
Guess what this tool was made from... :)
http://www.panix.com/~alvinj/file12/ignitiontool.jpg
Alvin in AZ
Old Sep 13, 2009 | 07:45 PM
86sixbanger's Avatar
86sixbanger
Yeah I don't get that, they put a release button on the light switch that lets the whole shaft slide out, but not on the wipers. But it's easiest just to find the little notch in the switch *****, they will have little lock tabs in them that let the **** release when pushed the right way with a small flathead screwdriver.
Old Sep 13, 2009 | 08:08 PM
truckrider814's Avatar
truckrider814
I found a small allen wrench works good too cause its got the 90* turn in it
Kyle
Old Sep 13, 2009 | 08:09 PM
Alvin in AZ
That's because you aren't thinking very hard? ;)
Think about how the two ***** are used differently. :)
Alvin in AZ
Old Sep 13, 2009 | 10:29 PM
86sixbanger
Alvin in AZ
Okay you tell me??? all I can think off is that the two switches are completly different switches and that the wiper switch's design does not allow it to have a shaft release???
Old Sep 13, 2009 | 11:17 PM
Alvin in AZ
design does not allow it to have a shaft release???:-X15
Ok, cool. :)
The light switch needs to be strong when you pull out on it, right? :)
So, they spent extra money on that switch to keep from having trouble.
The wiper switch isn't pulled except by accident, so all it really needs to
do is be strong enough for twisting and so they could make it cheaper.
There, now how's that sound to you? :)
Pretty obvious now huh? :)
Alvin in AZ
Old Sep 14, 2009 | 05:00 AM
EPNCSU2006's Avatar
EPNCSU2006
I have an 87 too. There is a small notch on the back of each ****. Insert a small flathead screwdriver or small allen wrench, as someone else suggested, in the notch and pull towards the face of the ****, then pull the **** off the shaft. That will let you get the trim piece off and get to the mounting screws for the switches. Or did I misunderstand what you're trying to do?
Old Sep 14, 2009 | 06:26 AM
460/5's Avatar
460/5
Zombie Survivalist
um, i have a 91, and my light switch completely died at 2 in the morning on I-80 while i was pullin a 40ft trailer. i got to a truck stop, bought three toggle switches, and pulled the ***** off to get the dash panel off. all i did was pull on em. and then i rewired my lights to three toggles switches: one for the dome light, one for the dash and parking lights, and one for the headlights. to my knowledge, im the first to remove these ***** cause it took some force, but all i did was pull. hehe.
Old Sep 14, 2009 | 08:06 AM
spinach's Avatar
spinach
Exactly, I just want to get the trim off, to remove the switch. The wiper motor is probably what is bad, and not the switch anyway, but I still want to get those dang ***** off!
Shadowrider123
Sep 8, 2014 04:56 PM
Indecl
Apr 8, 2012 05:30 PM
powerstrokedieselfan
Oct 11, 2010 09:11 PM
MintFord
Dec 23, 2006 07:57 PM
76 F250 4X4
47
Oct 30, 2003 11:32 PM
