Removing dash knobs
Old Apr 8, 2012 | 03:35 PM
Indecl's Avatar
Indecl
Removing dash *****
79' F-150 Ranger XLT. How in the world do you remove the ***** on the light and wiper switches so remove the front of the dash?
Old Apr 8, 2012 | 03:53 PM
devino246's Avatar
devino246
For the washer ****, there's a little notch in the **** that you stick a small screwdriver in a pull toward you.
For the light ****, you'll reach up under the dash and feel for a little button on the light switch. Press the button and pull the **** out. The shaft will come out with it.
Old Apr 8, 2012 | 03:56 PM
Silvabullet78's Avatar
Silvabullet78
For the wiper you need to either reach under the dash, or pull the instrument panel out and on top ofvthe wiper relay there is a button you have to push, the whole *** and rod will come out. For the light there should be a screw on the bottom ofvthe **** or just pull it should pop off, atleast thats how mine is
Old Apr 8, 2012 | 04:17 PM
Indecl's Avatar
Indecl
Thanks for the replies, we got it while I was waiting for an answer. Though I do have another one, any particular place you can stick a volt meter or any other reader to see if power is getting to a bulb vs. the bulb being blown?
Old Apr 8, 2012 | 05:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Silvabullet78
For the wiper you need to either reach under the dash, or pull the instrument panel out and on top of the wiper relay there is a button you have to push, the whole **** and rod will come out.
For the light there should be a screw on the bottom of the **** or just pull it should pop off, at least thats how mine is
What the heck are you talking about? All this info is totally wrong!
The wiper **** has a spring steel clip within it that retains it to the wiper switch shaft. The shaft is made as part of the switch, does not come off.
Below the clip, the **** has a notch in it. All it takes to remove the **** from the shaft is to 'trip' the clip using a small blade screwdriver.
At the bottom of the headlamp switch is a spring loaded button. Press that in and while holding it in, the **** and shaft (it's a one piece assembly) can then pulled from the switch.
To place the **** and shaft back into the switch, line it up and push it back in. There is no need to push on the button.
Since the OP has a 1979 F150...
D4FZ-11661-A .. Headlamp Switch **** & Shaft Assembly.
Applications: 1975 F100/350 from serial number V80,001 / 1976/79 F100/350 / 1978/79 Bronco // 1973 Pinto/Bobcat from 6/1/1973 / 1974/80 Pinto/Bobcat.
D3OZ-17513-B (replaced D3OZ-17513-A) .. Wiper Switch ****.
Applications: 1976/79 F100/350 / 1978/79 Bronco // 1973/76 Torino / 1974/76 Thunderbird / 1974/80 Pinto/Bobcat.
72CC428
Jun 2, 2016 03:25 PM
Fydaman
Jan 27, 2012 03:15 PM
albinorhino
May 31, 2011 09:56 PM
86F150302
Dec 14, 2007 08:05 PM
tmwindham
Electrical Systems/Wiring
Nov 5, 2004 12:18 AM
