7-pin trailer connector/ brake controller q/a
I have a dumb question... my truck came with the factory 7pin trailer connector and I wanted to know if the truck internally modulated trailer brake control or if it was like the 87-97 trucks where the wiring was ran in the truck and the connectors were just hanging under the dash for quick controller installation??? I should know this by now but nobody or the manual can satisfy my curiosity
FYI....
I found mine at a boneyard...
I was fortunate enough to find a SD that had a Prod. brake controller and the pigtail still attached under the dash. Swipe both with the bracket for about 9bux. It was cheap b/c it was considered "misc. electronics"- and he didn't bother with charging for the pigtail.
I also found one last week in our body style F150 that was still bagged w/the rest of the components (relays and such) in the glove box...
Just thought I'd pass along another means of acquiring the pigtail.
I think mine still has a factory p/n on it. If you need a p/n I can see about taking note of it when I go digging under my dash later today.
When I bought my Prodigy controller I also bought the harness for the truck and controller at the same time that made it a true plug and play installation. The whole install took 15 minutes and no wires needed spliced. The harness cost $12. I just plugged the harness adapter to the facory wiring harness plug and the other end to the controller.
Here it mentions a model specific adapter harness that can go from a model/brand specific Controller to the connector under the dash (without using the tow/brake controller pigtail harness).(The first 30secs mention this specific harness) http://www.etrailer.com/tv-brake_con...Ford_F150.aspx
...but of course the host of the video is utilizing the pigtail that came with the truck w/tow package.
I do have the harness and controller out of my truck sitting here.... But it has a small slew of p/ns on the label.
On edit: what year is this on?
This link is for a Prod. with the F150 specific harness/adapter plug.http://www.etrailer.com/p-90185-3035...eid=2005106261
Just go to your local dealership and test drive a couple F150s till you find one with a new harness in the glove box and swipe it.
I was given a loaner at one point last year that still had one in the glove box so i swiped it for my friend. I know im a real jerk, but that dealership screwed me over way more than the cost of a pigtail.
... is it still OK to steal it?
Hurricane Ditka
1999 to 2016 Super Duty
08-23-2011 10:49 AM
Rick_W
05-16-2009 06:47 PM
flyloki
08-28-2002 06:26 PM
