E4OD Crossmember
Old Sep 10, 2009 | 06:28 AM
danlee's Avatar
danlee
E4OD Crossmember
I'm putting an E4OD trans into an '83 F100 with a 5.0 motor. I need a 1 3/4" longer crossmember, since the mount is 8" further back and the frame rails are wider at that point.
I think that a F150/F250 crossmember from a vehicle with an E4OD trans should work.
What year truck should I look for to get the right crossmember?
Does anyone have a suitable donor vehicle?
Old Sep 10, 2009 | 08:50 AM
jas88's Avatar
jas88
I have one out of a 1991 F150 2wd and also one out of a 1991 Bronco - is your truck 2wd or 4wd? The 2wd one is flat and bolts to the frame "lip" on both sides, the one from the Bronco bolts to the lip on the driver's side but curls up around the frame on the pass. side and bolts to the outside of the frame rail.
Old Sep 10, 2009 | 06:30 PM
danlee's Avatar
danlee
jas88,
My truck is a 2WD. My present crossmember bolts to the frame 'lip' on both sides. I will measure the present crossmember and post it here. Please measure yours. We can take this offline if it's compatible.
Old Sep 11, 2009 | 01:25 PM
danlee's Avatar
danlee
jass88,
The crossmember in my '83 is 35 1/4" in length. I need one about 37" in length.
Old Sep 12, 2009 | 12:06 PM
jas88's Avatar
jas88
Oh, then I don't have what you need. Mine is 35 1/4 from hole to hole. It was removed from my 1991 F150 when I swapped from E4OD to ZF5 trans.
Old Sep 12, 2009 | 06:30 PM
danlee's Avatar
danlee
My measurement is from end to end, not hole to hole.
Old Sep 13, 2009 | 06:17 PM
jas88's Avatar
jas88
End to end mine is 36 1/4".
Old Sep 13, 2009 | 06:34 PM
danlee's Avatar
danlee
That makes it 3/8" too short on each side. I'll check tomorrow to see if I can live with that.
Old Sep 15, 2009 | 03:18 PM
danlee's Avatar
danlee
I think that will work. I'll send you an email, and we can discus the cost.
One Sock
Mar 10, 2014 04:39 PM
myakkacracka
19
Oct 11, 2013 09:10 AM
Supercouper
Dec 20, 2010 07:19 PM
masterguns2003
Jan 24, 2008 04:36 AM
7.3burnoutbuddy
Feb 24, 2006 06:21 AM
