Removing Airpump for power
Old Sep 11, 2009 | 10:30 AM
subford's Avatar
subford
Originally Posted by MEDF150
I printed the drawing off and drew arrows on it. It looks like the crank is clock-wise and the water pump counter clock-wise on all drawings. It appears these options are all viable.
I think you had better try that again, there is no-way.
Old Sep 11, 2009 | 03:40 PM
MEDF150's Avatar
MEDF150
I didn't think so either until I printed the drawing and put a clockwise arrow on the crankshaft and a counter -clockwise arrow on the waterpump on each version. I then put arrows on the belt following the direction of the crankshaft and the waterpump goes the correct counter clock-wise direction each time. Visually it doesn't look right, but with the arrows being drawn on it works.
(Not meant to start anything here.) BTW my truck is still running great after the ECT fix you guided me to. Thanks again!
Old Sep 11, 2009 | 03:51 PM
EPNCSU2006's Avatar
EPNCSU2006
Thanks for posting the belt lengths. That's some good information that hopefully will save someone some time.
It doesn't matter what side of the water pump that the belt rides on, as long as it crosses over between the crank pulley and the water pump pulley. All the diagrams posted above have the water pump turning in the same direction - opposite of crankshaft rotation.
Old Sep 11, 2009 | 03:54 PM
subford's Avatar
subford
Yes you are right.
Old Oct 19, 2009 | 09:48 AM
greenmachinejohn's Avatar
greenmachinejohn
I bought an "off road idler pulley" from California Mustang. I put it on my 1995 f-150 351W. All i had to do was buy an inch shorter belt and it runs great. Bolts right on. The belt size needed was a 101 inch belt. can send part numbers if needed. Pulley costs around 50.00 and the belts another 20.00. Had to remove my air pump because it froze up and broke my tensioner. i replaced all idlers while i was there. Also plugged the vaccum lines thanks to the forum on it. Truck runs better than ever.
Old Jan 14, 2011 | 09:19 PM
DieselDanB's Avatar
DieselDanB
Originally Posted by subford
I looks like you are running the WP backwards in two or three of the drawings.
Is this your power savings, no water pumping?
I just went through this ... 351 5.8 1990 F350 4x4 removed Smog pump
91" Belt perfect fit everything runs in the correct direction ..!
Old Jan 14, 2011 | 11:07 PM
Encho's Avatar
Encho
The Southernmost Mod
If it's working, leave it alone, my MPG took a turn for the worse when i took my air pump out (i can't find a spare one around here). I also got no gains in power at all. Avoid this mod.
Old Jan 14, 2011 | 11:23 PM
MariosF250's Avatar
MariosF250
This MOD wouldnt be bad if their was a was a way to flash our ECU so that the ECU would compensate for what is no longer their and run efficiently. i lost 2 miles per gallon on my 460
Front tank was getting 12mpg now get 10
Rear tank was getting 10 now get 8.
Mario
Old Jan 18, 2011 | 08:06 AM
nstueve's Avatar
nstueve
x2... if it works leave it alone. No HP to be gained...
Old Jan 18, 2011 | 09:53 AM
xxshine's Avatar
xxshine
AS long as the water pump continues spinning the same direction as the factory setup, it's O.K. If the water pimp is spinning the opposite direction, cause of belt routing, then a water pump from an earlier model will be necessary. Look for a year that the pump pulley was driven by a V groove belt. Those all went clockwise as one faces the front of the motor.
ola1234
Dec 3, 2016 06:56 PM
Rusty_S
Jan 26, 2016 09:59 PM
Midnite1987
41
Nov 10, 2012 07:56 PM
m350
Apr 30, 2012 06:53 PM
L n L
Apr 20, 2011 08:37 AM
