Never ending wheel bearing problem
Old Sep 5, 2009 | 10:15 AM
73pwrstrk's Avatar
73pwrstrk
ok so i just finished replacing all the wheel bearings on my front axle, along with new spindles and new hubs. i went on mitchell ondemand and got tq specs and everything. drove it for 30 miles and both side are locking up already. any help is greatly appreciated.
Old Sep 5, 2009 | 10:27 AM
Cuda_jim's Avatar
Cuda_jim
Describe your vehicle.
2wd or 4wd? F250/350?
What torque specs did you use?
I will assume you have a 4wd because you mentioned 'new hubs'
Auto or manual hubs?
Old Sep 5, 2009 | 10:53 AM
73pwrstrk's Avatar
73pwrstrk
its a 4x4. yes new wheel hub and new manual lockout out hubs. the tq for the inner nut was 18-20 something. i was told to just go with 20 so thats what i did.
Old Sep 5, 2009 | 11:20 AM
Cuda_jim's Avatar
Cuda_jim
I hope you didn't torque the nut to 20 ft-lbs, the bearings may be destroyed.
It's supposed to be 20 inch pounds (24 in-lbs = 2 ft-lbs) of rotational force to turn the hub........not the torque for the nut. There should be .000 to .002 play in the bearings.
This what you need to do:
Torque the inner adjusting nut to 50 ft-lbs while turning the hub, this seats the bearings and races. I guess you already did that
Back the nut off 90º
Install the retaining washer onto small pin sticking out of hub nut so the key is positioned in the groove of the wheel spindle. Tighten the inner lock nut, aligning the small pin into the nearest retaining washer hole.
Install the outer lock nut and tighten to 160-205 lb-ft
Check end play of the hub. It should be 0.000-0.002 inch. A little loose is better than too tight.
Torque required to rotate the hub should not be more than 20 lb-in after the outer nut has been torqued to 160-205 ft-lb
Old Sep 5, 2009 | 11:27 AM
73pwrstrk's Avatar
73pwrstrk
wow i cant believe it. so its binding up cause its to tight then? i guess its time to rip it all apart check bearings and redo correctly. thanks alot ill let ya know my outcome.
Old Sep 5, 2009 | 11:30 AM
Cuda_jim's Avatar
Cuda_jim
I just added a picture above after you already replied.
Yep, you had the inner nut too tight. Be sure to give a good look see on the bearings and races.
Hope they're OK.
Old Sep 5, 2009 | 11:36 AM
73pwrstrk's Avatar
73pwrstrk
yeah, thanks alot. i was ready to put it a blaze lol after 1500 in the front end and it still was f**kin up mabey next time i do something ill read directions alittle more careful
Old Sep 5, 2009 | 05:35 PM
Talyn's Avatar
Talyn
Yea. That's a common mistake man. =)
Most of the idots at the repair centers throw them suckers on with an impact. I'm surprised they don't go bad.
Just make sure you buy good bearings. Your truck will love you more
Some SMKs (i thnk tahts the right letters) or timkins or what not.
Old Sep 9, 2009 | 01:21 AM
73pwrstrk's Avatar
73pwrstrk
so i got the wheel bearing done but only got to test drive her for about 5 min till my rear end decided grenade...my truck f***king hates me for some reason...
Old Sep 9, 2009 | 01:29 AM
95_Dually's Avatar
95_Dually
Dude, that so SUCKS. I am sure you have the front repaired correctly after receiving the instructions.
How bad is the rearend. Have you taken the diff cover off yet?
Old Sep 9, 2009 | 02:02 AM
73pwrstrk's Avatar
73pwrstrk
yea i already have the gear set pulled. my left side gear only has 2 teeth left on it and the 5 out of the 7 clutches on the left side have the 2 nubs busted off them and the top 2 are cracked. all the damage was basically only done to the left side, not sure why. any ideas
Old Sep 9, 2009 | 07:37 PM
95_Dually's Avatar
95_Dually
No, I don't know why it only happened to one side and not both. It sure seems odd though. According to your post you mentioned clutches so I am assuming it is a Limited Slip. Perhaps the clutch material (spring parts or whatever) got lodged in the teeth and caused them to bind and self destruct.
Old Sep 10, 2009 | 03:45 PM
73pwrstrk's Avatar
73pwrstrk
yea thats what it looks like, its just weird like you said that its only one side. but parts are on the way and once this is done the damn thing almost brand new with all the **** thats broke on me this past year.
ArtsBest
Sep 24, 2010 12:25 AM
jgilrfr
Sep 22, 2010 01:20 AM
togobefastguy
Dec 15, 2008 03:01 PM
bpctcb28
Offroad & 4x4
Aug 15, 2005 06:52 PM
CalRanger
Dec 7, 2004 12:04 AM
