Offroad & 4x4
Dana 60 spindle bearings
Old Aug 14, 2005 | 08:41 PM
bpctcb28's Avatar
bpctcb28
What is the best way the get the old bearing out of my spindle, so I can install the new one? I managed to get the wheel bearing races out of the hub, but the spindle looks harder (cramped!).
Old Aug 14, 2005 | 08:43 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
drive a small screw driver on the outside of it, then progress to a chisel to make it deform, then you can pry it out
Old Aug 14, 2005 | 08:47 PM
bpctcb28's Avatar
bpctcb28
Can that be accomplished without hurting the spindle? I've tore up enough parts this week! Thanks for the help.
Old Aug 14, 2005 | 10:39 PM
RubberDuck's Avatar
RubberDuck
I use a piece of 7/16 square stock slightly bent at the end. I stick it through the hub end and tap it out like you did the other bearing races. Nothing to it.
RubberDuck
Old Aug 14, 2005 | 11:16 PM
proeliator's Avatar
proeliator
Yup, just drive it out. Its all the angle of the dangle. You can keep the old one to drive the new one in, just like you do with the races.
Old Aug 15, 2005 | 03:34 AM
RubberDuck's Avatar
RubberDuck
But be careful....If the angle of the dangle, does not equal the mass of the azz, things could get hairy, and nobody wants that.
RubberDuck
Old Aug 15, 2005 | 06:12 PM
bpctcb28's Avatar
bpctcb28
Thanks for all the info. I'm upgrading to 35 spline stub shafts and can't wait to get it back together.
Old Aug 15, 2005 | 06:52 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
RubberDuck
Also, don't forget that the angle is also inversely proporional to the heat of the meat. Anywhere close (angle-wise) is close, but be careful, too much angle equals a not-so-hot situation!!!
Cody
trevorrules
Jul 23, 2013 05:22 PM
PRIMERED79 SHORT BED
Feb 27, 2012 06:52 PM
CraigOutdoors
Mar 28, 2010 09:28 PM
Dog_Driver
May 4, 2004 02:27 AM
brnc
Bronco II
Feb 3, 2003 08:21 PM
