Sponsored by: Real Truck
Suspension Mod Question
Old Sep 4, 2009 | 02:13 AM
RagdollRacer's Avatar
RagdollRacer
I have the opportunity to install a set of the braces that go from the frame to the axles. I forget what the proper name is for them. (CRS).
Question: Do any of you guys have these braces and are they worth the effort?
Q2: What exactly is the advantage of this mod?
2003 F250 V10 CC FX4 with 4" lift DC3s and 35" Terra Grapplers
Thanks.
Old Sep 4, 2009 | 03:34 AM
orng1's Avatar
orng1
Ladder bars?
Old Sep 5, 2009 | 12:34 AM
RagdollRacer
Seriously. What are the bars called that look like swing arms that go to the axles from mid-frame and what is their purpose.
Old Sep 5, 2009 | 04:50 AM
Robs06SuperDuty's Avatar
Robs06SuperDuty
Ladder Bars. There to prevent axle wrap under hard excelleration.
Old Sep 6, 2009 | 02:54 PM
RagdollRacer
Ladder Bars...Are they useful or ar they mainly eye candy?
Old Sep 6, 2009 | 08:02 PM
LMS Residential's Avatar
LMS Residential
Rob is dead on. Ladder bars limit axle wrap and help to eliminate wheel hop under full throttle acceleration. On certain unibody car configurations they also, properly designed and installed, acted as sub frame connectors. The V10 in your sig probably has enough torque to make your drive wheel(s) feel like they're coming up on your fronts so the ladder bars would be more than eye candy, albeit more useful if you were racing your truck.
If not already equipped, the addition of a 1 1/4" rear anti sway bar may be a more useful suspension mod.
Old Sep 9, 2009 | 12:36 PM
RagdollRacer
Thanks, LMS. I do not race the truck but I do pull a 5ver and do a little offroading. As I understand it, there isn't much benefit for offroading just hotrodding. Is that correct?
SCRAPHEAP51
Feb 9, 2011 02:15 PM
Unrealo4
Nov 10, 2010 11:56 PM
wiseguy50
Jan 25, 2009 03:10 PM
darkman
Oct 26, 2003 04:43 PM
WC76TX
May 10, 2002 02:10 AM
