Intercooler brace?? what does this mod do??
Old Nov 10, 2010 | 10:14 PM
Unrealo4's Avatar
Unrealo4
I was in another part of FTE and saw a pic of a intercooler brace. what does this do? the thread was old so I doubt ill get a answer from the OP.
Old Nov 10, 2010 | 10:21 PM
bradyracing's Avatar
bradyracing
Who knows, mine doesn't have a brace and runs just fine. Can you be more specific.
Old Nov 10, 2010 | 10:31 PM
Unrealo4's Avatar
Unrealo4
I would love to be more specific. But im asking what the "Mod" is for. This is not a ford stock thing. So I will let ya know more when I find out.
Old Nov 10, 2010 | 10:48 PM
bradyracing
I see the pic now. That particular person has a problem with that boot blowing off because of high boost pressure. Do you have high boost pressure?
Old Nov 10, 2010 | 10:55 PM
Unrealo4's Avatar
Unrealo4
No, but I get a weird moaning noise that seems linked to rpm. I was wondering if it had something to do with turbo wiggles. /shrug
Old Nov 10, 2010 | 11:56 PM
loubell's Avatar
loubell
FYI that is the charge air cooler(CAC) tube. The intercooler is up in front of your radiator.
My oil soaked stock boots were so flimsy, that my CAC tube would flop around, resting on, and making contact with the trans dipstick and the glow plug module on the pass side valve cover. The simple brace that I fabbed up stopped this from happening. \
I have since replaced the factory worn out boots with Dieselsite's much thicker, stouter units (and they don't leak or seep oil). These boots are so stout, that I probably didn't need to put on the brace. But I figured with all of the heat cycles they would see, I might as well to stop any potential sagging and keeping it from taking a 'set' that way.0
A pic of the simple one I fabbed up with a muffler hanger and a large hose clamp. Without the muffler hanger, the tube has no give, and when the engine torques, it would only move the boot at the intercooler. The way I designed it, both boots and the tube will move just a little, instead of all of the movement happening at one place.
crandallf150
Aug 20, 2016 05:30 PM
AKBray907
1997 - 2003 F150
Feb 2, 2015 01:51 PM
ryans88gt
37
Dec 23, 2013 05:24 PM
checksix
Sep 14, 2012 07:59 PM
Beast12
Oil & Lubrication
Jul 24, 2005 04:12 PM
