highboy t.case brace
Old May 7, 2002 | 11:56 AM
WC76TX's Avatar
WC76TX
I am wondering why some trucks have a brace going from the transfer case back to a crossmember and some trucks don't. I pulled a NP203 out of my '75 f250 4x4 and replaced it with a 205 and now the brace is to short. the 205 came out of a '76 f250 4x4 and it never had this brace because the bracket is not on the crossmember for it.both are longbed reg. cab 133"wb trucks. do I need this? is it only on the trucks that come with the NP203? and will it hurt the mounts if its not there? these may sound like dumb questions but I was just wondering why they used it on one and not the other. any ideas anyone?
Will
Old May 7, 2002 | 02:32 PM
luv70sfords's Avatar
luv70sfords
My dads 205 has the brace. Im not sure which trucks get it and which dont, I imagine it was an option available to the buyer or somethin. We've been runnin without it for quite sometime and havent had any problems, but Im sure it does increase the wear on the t-case mount bushings.
Old May 9, 2002 | 08:32 PM
Scot's Avatar
Scot
I read somewhere it was a recall done to fix a driveline vibration problem. By the time I found out about it, the part was no longer serviced.
Old May 9, 2002 | 08:38 PM
luv70sfords
Old May 10, 2002 | 02:10 AM
karljay's Avatar
karljay
I heard it was for the divorced TC because it could shift out of gear under certain loads. The Ford manual for my 73 shows it and mine doesn't have it but it's easy enough to make one.
My TC used to slip out of gear because of movement, then I re-adjusted the shifter but having the brace would be better.
byerks
Apr 27, 2015 03:21 PM
ALBUQ F-1
Apr 7, 2015 08:22 PM
Pipelinewelder20
15
Oct 2, 2014 03:56 PM
parkerparkerm
Jan 23, 2014 08:28 PM
markkay4356
Nov 20, 2013 12:56 PM
