57 Hood Braces
Old Oct 25, 2003 | 08:42 PM
darkman's Avatar
darkman
57 Hood Braces
There are several under hood brace designs on the 57 - 60 trucks. Mine a 57 is the weakest of all I've seen. If it ever was glued to the hood it has long since turned loose and the hood was very flimsy when you tried to raise it twisting from side to side and never raising equally. Now I can't fix it till I replace all the front sheetmetal and have everything aligned correctly but I have to ask the questions as I think of them.
How or what do I do to reattach the brace to the hood? It appears to have a 3/4" gap. My singular brace runs side to side across the back of the hood underside.
Has anyone else encountered this problem?
Old Oct 26, 2003 | 04:43 PM
bhabben's Avatar
bhabben
Charles,
Is the back brace anything at all like the back brace in my '59? Is it spot welded to the pinch weld at the back and sides. Does it look like the 3/4" gap at the front is caused by the brace bending down at the front? Does it look like it could be bent back into place?
To keep it that way, I can think of a couple of options.
Glue the brace to the skin using modern panel adhesive (like something by SEM). But I would be afraid that that may pull the skin down when the brace bends, leaving visible ripples.
Adapt a set of front-to-back braces off the later hoods like my 59.
Fab another stiffener applied to the front edge of your existing back brace to keep it from bending. I've even seen rebar rigged for this purpose on junkyard trucks. You could create something prettier that most people would not even notice as 'non-stock'.
Anybody else?
Adios,
Brett
avf100
13
Jul 19, 2023 04:16 PM
mrcman58
Ford Truck Parts for Sale
Apr 13, 2017 03:49 PM
Smitty49
Sep 22, 2015 06:39 PM
71LTD390
34
Mar 17, 2015 09:15 PM
keystoneaz
Nov 9, 2014 08:09 PM
