93' Ranger problem
Old Oct 7, 2009 | 03:14 PM
tomw's Avatar
tomw
From what I have heard, you need ALL the fasteners on, clean, and tight for it to work properly. Maybe I am mistaken, but have a memory of someone skipping one or two, and the thing not working.
tom
Old Oct 7, 2009 | 10:08 PM
93'ranger2wd's Avatar
93'ranger2wd
OK, it's probably a grounding issue from the coil pack. I do have a wire running from the coil pack to the frame to see if that is what it is. So far it has not done it yet but it has only been a day. Will see. Thanks
Old Oct 22, 2009 | 10:43 PM
93'ranger2wd
Ok, update I replaced the screws for the coil packs and it has not cut out at all. So if someone is having this problem then I suggest to replace all of the screws first before you replace the coil packs. Makes better sense to spend 1 or 2 dollars for screws then to spend about 100 bucks for 2 coil packs. Just a suggestion. Lol!!
edgar gonzalez
Jan 2, 2016 12:47 AM
1998Ranger25L153CID
Oct 27, 2006 06:29 PM
rangerrod
4 Cylinder Engines
Jun 30, 2006 12:18 AM
94ranger23
Jun 26, 2006 12:04 PM
BroncoRoadKill
Feb 2, 2005 09:49 PM
