04 6.0 problems
Old Sep 3, 2009 | 08:21 AM
rocky1074's Avatar
rocky1074
Thanks Mark, I will look for the EBP Sensor sometime today, hopefully I will find it. First I must try to find out the engine build date which I don't know if it was build before Sept, 2003. Any sure way to find the built date???? I could sure use any help I can get. Thanks Rocky
Old Sep 3, 2009 | 08:28 AM
npccpartsman's Avatar
npccpartsman
Look at the VIN tag in the door. 9/03 is an 03 motor. 10/03 is an 04 motor.
04 motors also have the IPR valve in the passenger side front of the valve cover. gold sensor with 3 wires. ICP sensor is still under the turbo, unfortunately.
Old Sep 3, 2009 | 10:45 AM
rocky1074's Avatar
rocky1074
Ok Thanks Partsman, But sometimes I think this Florida sun baked my brain. I purchased the truck in June 03 NEW Sooooooooo tha of course it's 03 motor...LOL Thanks Rocky
Old Sep 3, 2009 | 06:02 PM
bblancha's Avatar
bblancha
Alright i brought my truck in today to the shop the code he keeps getting is P132B eanybody have eany idea what it means.
Old Sep 3, 2009 | 06:12 PM
bismic's Avatar
bismic
If you have had your computer flashed (updated program), then you do not use your EBP sensor (with your build date).
P132B is a code related to the calibration from the recall 06E17 (this is the EBP elimination flash, so it looks like you have had it done). It means that there is a problem with the VGT system. P132B is a fault code that is set if the required boost levels are not achieved during a learn cycle or at specific speed fuel demand points. This code indicates that there are issues with the turbocharger, MAF sensor, MAP sensor/hose, IAT2 sensor, intake leaks, or exhaust leaks, etc.
Old Sep 3, 2009 | 06:44 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Wow, all this time I thought I had a late 03 motor, but I have an early 04 Learn something new every day!
Old Sep 3, 2009 | 07:13 PM
bblancha's Avatar
bblancha
Its deff not the map sensor the mechanic i brought it to today tried a new one and didnt work. He wasnt shore what the code ment so he said he will check on it tonight but i guess i will beable to tell him now. Is eany of them sensors expensive or hard to change to you no off hand.
Old Sep 3, 2009 | 07:18 PM
bismic's Avatar
bismic
I think the MAF/IAT1 is expensive (at least according to my sometimes questionable memory). Not sure about IAT2
Check them out at y2kfordparts
<TABLE style="WIDTH: 495pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=660 x:str><COLGROUP><COL style="WIDTH: 495pt; mso-width-source: userset; mso-width-alt: 24137" width=660><TBODY><TR style="HEIGHT: 33pt; mso-height-source: userset" height=44><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: yellow; WIDTH: 495pt; HEIGHT: 33pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=44 width=660>http://www.trademotion.com/partlocator/index.cfm?siteid=214072</TD></TR></TBODY></TABLE>
Old Sep 3, 2009 | 07:21 PM
bblancha's Avatar
bblancha
Also if you have eany pics of where the MAF sensor and IA T2 sensor are located that would help allot also.
Old Sep 3, 2009 | 07:26 PM
bblancha's Avatar
bblancha
The MAF is only 20$ per side i cant find the IAT2 sensor.
Old Sep 4, 2009 | 05:54 AM
npccpartsman
The MAF is $132 from that link. What you found was some kind of wire extension. There is only one MAF in a 6.0 and it doubles as the IAT sensor. The IAT2 sensor is $35 from y2k. Look under air cleaner parts for a 6.0 and you'll find the links.
indyraven
Jul 8, 2013 09:30 PM
BFlemsr
Nov 16, 2012 06:38 PM
tbomber7
May 8, 2012 03:13 PM
wvumtneer
Aug 18, 2010 06:17 PM
fomoconut
Apr 13, 2007 12:17 PM
