EGR Delete Kits
Old Mar 24, 2011 | 04:36 PM
tbomber7's Avatar
tbomber7
EGR Delete Kits
Are a EGR valve Delete kit and EGR cooler Delete Kits the same thing or seperate? Should i Delete Both? by reading i have come to understand the EGR system causes a lot of problems in the 6.0L is this true? has any one installed one without removing the intake manifold?
Old Mar 24, 2011 | 05:37 PM
wezol5484's Avatar
wezol5484
They are the same thing. When you do an EGR delete, you are either
1) removing the EGR cooler and putting a new up-pipe in it's place
or
2) purchasing a EGR cooler that has been welded up to prevent coolant from entering the cooler. This kind of kit is used if you need to pass a visual inspection for emissions.
A lot of people use the Sinister kit, or Bullet Proof Diesel kit. There are a lot of threads and write ups in the forum, do a search and you'll find 'em.
Many keep the EGR in place and plugged in, even though it is not functional. You WILL get a CEL on trucks 05+, but keeping the EGR plugged in makes the fan happy. Read on this thread here about it.
https://www.ford-trucks.com/forums/9...lve-issue.html
Old Mar 24, 2011 | 05:43 PM
rdunagan's Avatar
rdunagan
you dont have to remove the intake but its much easier if you do. it takes a whole 10 more mins to remove when your right there. if i were you id go bullet proof egr cooler. i think im about to switch back to it. that way you dont have anything to worry about
Old Mar 24, 2011 | 05:48 PM
tbomber7's Avatar
tbomber7
Guess that would be a good time to do the oil cooler, she has 180,000 KM's
Old Mar 24, 2011 | 06:38 PM
rdunagan's Avatar
rdunagan
yep i would def do it!!!
Old Mar 24, 2011 | 09:17 PM
BobbyB's Avatar
BobbyB
Can you remove the intake without removing the turbo?
Old Mar 24, 2011 | 09:23 PM
rdunagan's Avatar
rdunagan
haha no i wish though!! sure would make life easier
Old Mar 28, 2011 | 06:12 PM
horn's Avatar
horn
Good info guys! Thanks
Old Mar 29, 2011 | 01:11 PM
rdunagan's Avatar
rdunagan
Ps don't delete the egr valve. The fan might not work properly
Old Mar 29, 2011 | 05:31 PM
BLADE35's Avatar
BLADE35
I am getting ready to cross this brige as well. why are you going back to a egr cooled system {emisssions,better milage?????}
I am in a area wear emmissions dont matter for the time being
so I could do either deleat or a bulletproof cooler?
being its an 03 not woried about a light either
Which way got better mileage?
anyone thanks
Old Mar 29, 2011 | 05:43 PM
rdunagan's Avatar
rdunagan
didnt get better mileage either way. im think about switchin back because i am commercial and its hard for me to get an inspection sticker. i hate the thought of hot exhaust gas and soot in my intake but im also tired of driving around looking to get an inspection sticker at the same time. i will have a better update soon being that im putting one on my brothers truck and i will be able to give more info on both a delete and cooler
Old Mar 30, 2011 | 02:09 AM
tbomber7's Avatar
tbomber7
i was understanding the delete kit would not trigger codes. am i miss informed?
Old Mar 30, 2011 | 09:08 AM
wezol5484's Avatar
wezol5484
They look at that stuff in Erath County for commercial? There's gotta be a place here in town that'll pass it....
Old Mar 30, 2011 | 09:10 AM
wezol5484's Avatar
wezol5484
Depends on the year model of the truck, 03 and 04 it won't. 05 and up it will, P0401 "low EGR flow".
Mine is on right now and that's the code I have (it's an 06). You can't notice any difference in drive-ability, and it actually has a little more "umph" to it down low. You will have to get a tuner in order to turn the EGR valve off through the PCM in order to get rid of the CEL. But, I would still leave it plugged in for fan operation.
Check this thread out.
https://www.ford-trucks.com/forums/9...egr-valve.html
Old Mar 30, 2011 | 09:17 AM
jdadamsjr's Avatar
jdadamsjr
From recent posts, some knowledgeable users here are now saying their research is saying to NOT remove egr.....
my fix was to use an sct custom tune from idp to turn it off.....
