blasted impeller
Old Sep 2, 2009 | 05:51 PM
Layson's Avatar
Layson
Might be worth the time to run a quick compression check...
Yes you should have called Clay first!! LOL
Old Sep 2, 2009 | 06:04 PM
wuttrd's Avatar
wuttrd
fill cap
filler neck just gave that try and the cap did blow off is that a good sign?thank you for the help.
Old Sep 2, 2009 | 06:16 PM
Tenn01PSD350's Avatar
Tenn01PSD350
No, it should not blow off. Is it puffing like the old steam locomotive engines?
Old Sep 2, 2009 | 06:18 PM
Layson's Avatar
Layson
That means you have lots of blow by... some engines have a lot while others do not. Probably not a good thing to have a lot... if you know what I mean... LOL
If you have time.. just might be good to do a compression test. See if Clay has a compression test kit yet. If you are changing out glow plugs then it would be a perfect time...
Old Sep 2, 2009 | 06:51 PM
Izzy351's Avatar
Izzy351
That cap should just set there like mine does. Does it vibrate off like mine almost did, or does it actually get some altitude as the puff blows it off the filler neck?
It could just mean a clogged CCV -- check that first, and if all else fails, a compression check would be in order like Layson said...
Old Sep 2, 2009 | 11:08 PM
PaysonPSD's Avatar
PaysonPSD
Wuttrd,
Where in AZ are you located? I am willing to take a look at your truck.
Old Sep 3, 2009 | 02:04 AM
WA.Ranger's Avatar
WA.Ranger
Originally Posted by PaysonPSD
Wuttrd,
I would take full advantage of this offer from a Very Knowledgeable man! Reps to you Robin!
Old Sep 3, 2009 | 08:40 AM
wuttrd's Avatar
wuttrd
filler neck
sorry i read the answer wrong. when i put the cap on the filler neck it did NOT BLOW OFF, it had a vibrate issue. so i belive that is a good sign. i am located in lake havasu city, az and thanks again for the help i defentaly need it.
Old Sep 3, 2009 | 08:48 AM
Izzy351's Avatar
Izzy351
Good news... If you want a nice, smooth running engine, do the in-tank mods and get an HPX. It really smooths that puppy out, as you can see.
Old Sep 3, 2009 | 08:58 AM
wuttrd's Avatar
wuttrd
blow by
GOOD NEWS thank you for the info
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
russellkr
Nov 2, 2002 11:18 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
