blasted impeller
Old Sep 2, 2009 | 08:19 AM
wuttrd's Avatar
wuttrd
Exclamation blasted impeller
how hard are they to change out for a new one ??? i have a photo but for some reason i cant find the attachment button thank you
Old Sep 2, 2009 | 08:29 AM
F350-6's Avatar
F350-6
You've got to have 25 posts before you're allowed to attach pics. Are you referring to the intake wheel in the turbo? It's not too bad a job. Make sure you get some o-rings for the pedestal. http://www.dieselsite.com/pdffiles/ww.pdf
Old Sep 2, 2009 | 08:37 AM
wuttrd's Avatar
wuttrd
Thumbs up inlet impeller
i will keep posting to show some photos. does the whole turbo have to come out or can i access it fromthe inlet ?? and are they spendy ??
thank you for your reply
Old Sep 2, 2009 | 08:38 AM
agg_bagg's Avatar
agg_bagg
or you can do it without removing the turbo that way you don't need the o-rings. unless the compressor housing uses one that you need to replace. that i don't know
Old Sep 2, 2009 | 08:51 AM
Nick 99's Avatar
Nick 99
What was the cause of the turbo damage?
Old Sep 2, 2009 | 09:44 AM
Izzy351's Avatar
Izzy351
Yes, you can do it without taking it off. Even without taking the housing loose from the waste gate. That's how I did it. You have to drop the exhaust down-pipe, wrap a long screwdriver with tape (I used duct tape), and stick it in the exhaust wheel blades. I actually used two screwdrivers, just in case. The exhaust wheel CAN be damaged, but it's pretty stout -- it takes a lot of force to do that. DO NOT use an impact wrench to take off the wheel. You'll be beating the tar out of the thrust bearing. The wheel will clear the housing without taking off the waste gate stuff, you just have to get it at the right angle.
Old Sep 2, 2009 | 11:02 AM
wuttrd's Avatar
wuttrd
turbo
thanks for the replys. i just got back from the turbo shop. the turbo is shot inter splines and impeller so i am having one built as we type. one thousand dallars later the pohots would tell the whole story. long story short keep an eye on that turbo inlet hose part # F81Z-9C681-BA hopfully soon the bugs will be gone
Old Sep 2, 2009 | 11:18 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Oh man... sorry to hear that. But what "inner splines" are you referring to? And not to rub salt in a wound, but for about $220 you can get a rebuild kit for the OEM turbo, an early-99/Wicked Wheel, and the pedestal o-rings and easily do it yourself in an afternoon.
Old Sep 2, 2009 | 11:59 AM
wuttrd's Avatar
wuttrd
turbo
yah i just found that out.(the hard way) just got off the phone with Clay. SHOULD HAVE CALLED HIM FIRST. wont make that mistake agan.
Old Sep 2, 2009 | 12:04 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here are the pics for ya.
Old Sep 2, 2009 | 12:10 PM
wuttrd's Avatar
wuttrd
Thumbs up turbo
thank you agan Clay you are the man. any other issues i am going to you first. THANK YOU !!
Old Sep 2, 2009 | 02:23 PM
Izzy351's Avatar
Izzy351
Holy smokes!! That thing has been eating A LOT of dirt!! How's the rest of the engine??
Old Sep 2, 2009 | 02:30 PM
WA.Ranger's Avatar
WA.Ranger
WOW!
Old Sep 2, 2009 | 02:53 PM
wuttrd's Avatar
wuttrd
Exclamation dirt
speaking of the rest of the engine, any idea of what to check so i will have no more suprises. thank you.
Old Sep 2, 2009 | 04:48 PM
Izzy351's Avatar
Izzy351
I would pull the entire intake system and clean it to the heads. Check your blow-by also. You should be able to do this with out the cap popping off of the filler neck:
