Connecticut Chapter Join Chapter, Leader:
September B/S thread
Old Sep 25, 2009 | 05:37 PM
  #481
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Good evening everyone.
Old Sep 25, 2009 | 06:00 PM
  #482
mox-ct's Avatar
mox-ct
Originally Posted by Aerocell4x4
Thanks Rich, but the link ended with the site giving me an error message.
Yah, needed to log in.
Try this one http://www.ct.gov/dmv/LIB/dmv/20/29/mvregs.pdf
  #483
sglaine's Avatar
sglaine
Posting Legend
Good evening
  #484
mox-ct's Avatar
mox-ct
Evening folks
Old Sep 25, 2009 | 06:15 PM
  #485
Aerocell4x4
Hi Rich, Thanks
Old Sep 25, 2009 | 06:26 PM
  #486
mox-ct's Avatar
mox-ct
Each ``passenger motor vehicle'' as defined in subdivision (35) of section 14-1 of the General Statutes operating on the highways of this state shall be equipped with a suspension system that complies with the following:
(a) Vehicle suspension configuration. Each motor vehicle shall be equipped with a suspension system consisting of the basic elements originally provided by the vehicle manufacturer and geometrically arranged in accordance with the manufacturer's specifications. No suspension system component shall be replaced unless such replacement component meets or exceeds the quality and performance standards established by the vehicle manufacturer and the safe operating characteristics of the vehicle on which such replacement component is installed are not adversely affected by such installation.
(b) Height adjustment limitations. No additional devices shall be installed or equipment substitutions made at any location on any motor vehicle when such installation or addition either:
(1) Raises the sprung portion of the vehicle in excess of four (4) inches above the vehicle's unladen height as established by the vehicle manufacturer; or,
(2) Lowers any part of the sprung portion of the vehicle so as to reduce the vertical clearance, between the sprung portion of the vehicle and a level surface on which it rests unladen, to less than four (4) inches.
(c) Spring replacement limitation. No suspension springs which have a load carrying capacity or spring rate below that specified by the vehicle manufacturer shall be installed on any vehicle.
(d) Shock absorber mounting limitation. No shock absorber shall be installed in any manner which will allow it to reach its extreme stroke limitation while the vehicle is being operated.
(e) Tires - Limitation. All tires on the same axle or on axles which are less than six feet apart must be of the same tire size with respect to diameter and maximum width. Each such tire shall have a load carrying capacity specified by the tire manufacturer in excess of the intended maximum axle load divided by the number of tires on the axle. Federal Motor Vehicle Safety Standard No. 571.109 shall apply in establishing the load capabilities of tires.
(f) Wheel track distance. No modification of a vehicle suspension system geometry shall result in any reduction of such vehicle's wheel track distance.
(Effective August 29, 1990)
Old Sep 25, 2009 | 06:31 PM
  #487
sglaine's Avatar
sglaine
Posting Legend
Good evening
Old Sep 25, 2009 | 06:38 PM
  #488
Aerocell4x4
Hi Sean
Old Sep 25, 2009 | 06:41 PM
  #489
sglaine's Avatar
sglaine
Posting Legend
How's the new house Dave
Old Sep 25, 2009 | 07:03 PM
  #490
Aerocell4x4
Hi Sean, waiting on us to close a week from Monday.
Old Sep 25, 2009 | 07:22 PM
  #491
sglaine's Avatar
sglaine
Posting Legend
Sweet and good luck with that
Old Sep 25, 2009 | 07:32 PM
  #492
Aerocell4x4
TY Sean
Old Sep 25, 2009 | 07:40 PM
  #493
Nice Work Truck's Avatar
Nice Work Truck
Evening guys.
I hope you all have a good weekend.
Old Sep 25, 2009 | 07:41 PM
  #494
7.3 Rocket's Avatar
7.3 Rocket
Evening, all. Too bad I can't keep "IC" boots on my truck and my trans isn't properly modded yet or I would be in the truck pull at the Durham fair. I'm sure some hopped up Cummins will take it, but it would've been fun to BS. Aside from that I've got no reason to go to the Durham fair any more. Too commercialized for me.
But if anyone here is looking to listen to a good Christian singer search for some music by Ryan Baker. I was just on a school retreat and he was actually the speaker and he had a mini-concert for us. he was offered a record deal by Sony BMG but they wanted to own 51% of everything so he said no and walked away. The producer he was talking to has dealt with Carrie Underwood, Taylor Swift, Reba, etc.
Old Sep 25, 2009 | 07:57 PM
  #495
sglaine's Avatar
sglaine
Posting Legend
Originally Posted by Nice Work Truck
Evening guys.
You also Andy and what are your weekend plans
