2000 Explorer Window Problem
Old Aug 31, 2009 | 06:11 PM
Sherroo74's Avatar
Sherroo74
My windows motor is fine as it will open and close the window however in order to due this I have to push down on the window or pull up as it has come off of the track. If I do not it will open on a bad angle and when I close it if I don't help guide it, it will pop right out. Does anyone know how easy this would be to fix on my own? Any suggestions?
Thanks.
Old Aug 31, 2009 | 09:07 PM
steve(ill)'s Avatar
steve(ill)
i would take off the door panel and look insdie. i guess a anchor bolt came loose and the track is not in position now. maybe some lube and readjust the track. should be able to see problem with the inner door panel off.
rbrad6937
Jun 3, 2018 12:06 PM
Stroker 6.0 fan
Dec 3, 2016 03:21 AM
Beeler
Nov 13, 2016 01:15 PM
mjunk1
1997 - 2003 F150
Jun 1, 2009 04:20 PM
websthes
Jan 25, 2008 04:02 PM
