Sponsored by: Auxito
Cap window lubrication ideas
Old May 29, 2009 | 01:54 PM
mjunk1's Avatar
mjunk1
I have a Century cap on my Screw - see pic in signature - and the side windows in that things are REALLY tough to slide. Anyone use a good lubricant or other technique for making them open and close better?
Old May 31, 2009 | 09:25 AM
l-m tech's Avatar
l-m tech
buy some dry silicone spray.it should do the trick.
Old May 31, 2009 | 09:58 AM
Bear River's Avatar
Bear River
Former ******
The best lubricants are those that lubricate without attracting too much dirt and grime. Thicker lubricants better meet the requirements you are after. White lithium grease would be very good. However, the spray type tends to dry out. If you could get the grease in a tube with a narrow point, you could put that right into the track. Gel lube would also work great, and it does come in a spray can. It is hard to find however. Molybdenum grease would probably be the best of all.
Old May 31, 2009 | 11:10 AM
GammaDriver's Avatar
GammaDriver
I'd agree with greases if you don't mind cleaning up the dirt they attract once in a while. Also, if you don't find a way to apply the grease in the track, and -only- inside the track, you can end up with grease on kids, pets, tools, and everything else.
A dry wax lube may be pretty good. Boeshield T-9, developed for Boeing aircraft, goes on wet, but the carrier evaporates leaving a clear wax that does not allow dirt to adhere (a good number of cyclists use it on our chains).
Old May 31, 2009 | 02:39 PM
Lavern's Avatar
Lavern
Graphite paint is the best thing in the world. We use it at work for our extendable trailers that are steal to steal (causes alot of friction) that stuff is 100 times better then grease or anything else and it will last a lifetime with one coat.
Old May 31, 2009 | 03:52 PM
GammaDriver
Graphite does seem like a better bet than grease for keeping build-up and dirt from accumulating. Do you have a product name of the graphite paint you guys use?
Old May 31, 2009 | 04:01 PM
Lavern's Avatar
Lavern
we used to buy it in a can from John Deere but we got some new stuff in a spray can from another company. I can get the name tomorrow.
Old Jun 1, 2009 | 10:29 AM
Lavern's Avatar
Lavern
The name is Certified Dry Lube. Certified also has different products. We bought this in bulk I'm not sure if you can get it at stores. I do know that there are different brands you could probably pick up at a parts store.
Old Jun 1, 2009 | 12:50 PM
1Aauto's Avatar
1Aauto
Former Vendor
Sounds like it's worth checking out.
Old Jun 1, 2009 | 04:20 PM
Lavern's Avatar
Lavern
It's awesome stuff. Don't know what I ever did without it.
Razorback2017
2009 - 2014 F150
Mar 23, 2017 03:13 PM
jeepguy1985
Mar 7, 2017 07:56 AM
darmento
Aug 2, 2016 03:07 PM
solidpvc
1978 - 1996 Big Bronco
Jun 13, 2005 11:14 AM
Kevlar7R
Dec 16, 2003 10:31 AM
