The Ford mechanic is saying that for injectors showed weak on the "buzz test". What does that mean? If I need to get new injectors should I take this as an opportunity to upgrade? And if so, what should I go with? I have a FASS fuel pump but no regulated return or anything else to the fuel system. I have been thinking of doing that though. I'm not rich so I what to spend wisely.
I can't help with you 7.3 question, except to say that if I was paying the bill, I would have them replace every injector at once while they are in there.
As for the info at the bottom, that is called a "Signature" and you can have one about 24 hours after you have 25 posts. You'll find the option appears in your USERCP. You have to design it, it is not automatic.
