Injector Stuck Need Advice ASAP
Old Aug 3, 2011 | 02:16 PM
LSO1123's Avatar
LSO1123
I'm taking the old injectors out of my 94 IDI turbo. The injector that is next to the fuel filter seems to be sized up. I can't seem to budge it but I haven't really torqued down on it yet for fear of screwing something up! What should I do? Should I just put a cheater bar on the ratchet and bear down on it or what?
Old Aug 3, 2011 | 03:25 PM
Fordranchero's Avatar
Fordranchero
Pending hearing better advice I would get some Seafoam deep creep and spray it around the base.
Try to torque it back and forth to get the stuff moving into it and let sit, try again.
Old Aug 3, 2011 | 04:08 PM
Phy's Avatar
Phy
PB Parts Blaster works pretty good, too...
Old Aug 3, 2011 | 04:09 PM
ford390gashog's Avatar
ford390gashog
I would use an impact wrench if you have one!! Not much you can screw up the worst that will happen is the injector will unscrew in two pieces and that is pretty easy to remove.
Old Aug 3, 2011 | 07:48 PM
LSO1123's Avatar
LSO1123
I finally got it out! It took me, my dad, a can of PB parts blaster, an impact gun, (weak one though), a boxed in wrench and a 4 pound hammer to get it out! There was so much carbon build up on the injector and in the hole that I seriously doubt this injector was working at all, which would explain why my truck had no power! I'll post pics of the injector and inside the hole in a few.
Old Aug 3, 2011 | 10:53 PM
LSO1123's Avatar
LSO1123
Here's some pics of the injector and one of the inside of the hole.
Old Aug 4, 2011 | 10:36 AM
PLC7.3's Avatar
PLC7.3
Next time if the injector separates on removal grind the top outer threads off. Reinstall the top on the injector now it can be turned to assist in the breaking loose of the injector...... Remember what ever falls or pours into the cylinder... fluid or carbon so as to avoid a hydraulic lock rotate the engine with the starter prior to re installation of the new injector.
Old Aug 4, 2011 | 11:42 AM
LSO1123's Avatar
LSO1123
I read about that injector removal trick on oil burners last nite. I did rotate the engine with the starter before I installed the new injectors hoping to blow anything that may have fell down into the combustion chamber out.
Old Aug 4, 2011 | 01:20 PM
typefour's Avatar
typefour
You need to scrape out all that carbon and get the copper washer out also.
Old Aug 4, 2011 | 02:48 PM
LSO1123's Avatar
LSO1123
I did that. That pic is before I cleaned all the carbon out. A dental pic works wonders for getting the copper washers out.
Xenthrax
21
May 16, 2013 02:41 PM
spdmpo
Feb 8, 2013 12:50 PM
4odd6
Oct 20, 2011 09:10 AM
AlarmGuy
Dec 31, 2010 01:33 PM
karlk808
Jan 29, 2006 02:09 PM
