1978 - 1996 Big Bronco
1980 transmission coversion
Old Aug 29, 2009 | 02:11 PM
Fresh's Avatar
Fresh
anybody change the 4 speed with manual clutch in an 80 with a 5 speed with hydrualic clutch? do you have to change the pedals to get it to work with the hydraulic system? i Have a 88 donor bronco with the 5 speed and wanting to put it in the 80 with a 4 speed. what would all need to be done?
Old Jun 2, 2010 | 06:16 AM
g_k50's Avatar
g_k50
Is there a reason you don't want to keep it stock?
Let's give'r a bump and see.
Old Jun 2, 2010 | 09:59 AM
AbandonedBronco's Avatar
AbandonedBronco
Definitely a reason not to keep it stock, if you have the money.
The mechanical clutch offered two 4 speeds. One was Granny, 1, 2, 3. The other was a 1, 2, 3, OD. The OD versions were aluminum and generally not very strong. The granny ones were strong, but offered no overdrive.
The 5 speed comes with the option of the ZF5, which is a stout transmission with a granny, 1, 2, 3, OD. Best of everything.
Gotta convert to a hydraulic clutch though. If you have the donor, switch everything over from the donor truck. Pedals, hydraulics, transmission, etc.
Old Jun 2, 2010 | 12:32 PM
g_k50's Avatar
g_k50
Funny, If I had money I would not cobble together a couple of Broncos, I would just buy a Bronco with the good transmission.
Old Jun 2, 2010 | 01:31 PM
AbandonedBronco
Depends on your view I suppose. I've put a lot of work into mine, and I'd much rather put a transmission in it a I like, than just get another because of the transmission.
RentAMan
Modular V8 (4.6L, 5.4L)
May 2, 2016 07:49 AM
ItsAFord55
Dec 8, 2015 06:24 PM
nightowl263
19
Dec 3, 2015 10:24 PM
gannonm
Nov 22, 2015 02:04 AM
Rogmatt
Jun 12, 2008 11:53 AM
