1978 - 1996 Big Bronco
door code help
Old Jun 2, 2010 | 03:27 PM
you.arestpid's Avatar
you.arestpid
door code help
i am trying to find out what my gear ratio is and whether or not i have a limited slip diff. the door code says H2. its a 1980 w/ 351w bronco, if anyone can help please do if i need to post more info i will
Old Jun 2, 2010 | 04:08 PM
NWBronco's Avatar
NWBronco
H2 is 3.50 gears. Most H's were limited slip. I have seen exceptions though.
Old Jun 2, 2010 | 04:18 PM
you.arestpid
thanks for the help! is that something you knew off the top of your head, or where you able to find it online?
Old Jun 2, 2010 | 04:21 PM
NWBronco's Avatar
NWBronco
I've got a mess o' stuff on this old PC. That info was in a spreadsheet I created from a few other sources.
Old Jun 2, 2010 | 05:17 PM
greystreak92's Avatar
greystreak92
Axle tags will reveal a lot too... they just require crawling further under the truck to get the information.
